> TPS sensor board replacement procedure?
Amphicar770
post Jun 30 2014, 10:40 AM
Hi all,
Before I go down what seems like the obvious but wrong path.
Just got a new tips sensor board from 914rubber.com.
When installing, shouldn't remove the tps assembly from the engine or leave it in place.
I was thinking it may need to come off but don't know if that opens a can of works in terms of linkage,gaskets, etc.
Thanks,
Mike
Amphicar770
post Jun 30 2014, 10:26 PM
Thanks. Changed it this evening, have not had a chance to test drive. Could definitely see the wear on the old one even with only 45k miles on the odometer.
One bit of oddness I experienced on my '74 2.0
I replaced the throttle position circuit board. Put the TB back on car, hooked up some jumpers and could not get a reading other than 1.
Figuring I might have the jumpers wrong I again removed the TB. Jumpers were correct and I was able to calibrate on the bench. Left the jumpers in place, put the TB back on car. Checked reading, still zero.
I now hook the linkage back up and notice the reading is back at 1. Loosen the screws, go to adjust and same as before, only shows 1 no matter how I turn the assembly.
Seems to be OK with bench calibration but not sure why I can't seem to calibrate on the car?
- Lo-Fi Version Time is now: 18th November 2026 - 05:44 AM
