| rhodyguy |
Jul 2 2014, 11:06 AM
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,252 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
mostly mike, do you recommend doing those as well while i'm in there? i don't want to cheap out on the rebuild. once and done...
k |
| McMark |
Jul 2 2014, 09:16 PM
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 20,180 Joined: 13-March 03 From: Grand Rapids, MI Member No.: 419 Region Association: None |
AKA Synchros.
Most of the time you can swap them fifth onto first, first onto fifth, second onto fourth, fourth onto second. Or if the investment doesn't bother you, about $350-400 for new bands on 1-2-3. |
| Mark Henry |
Jul 3 2014, 10:19 AM
that's what I do! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,065 Joined: 27-December 02 From: Port Hope, Ontario Member No.: 26 Region Association: Canada |
They have a rough darker surface, if they have a polished ring around them they are done. Good used is fine.
| Cap'n Krusty |
Jul 3 2014, 11:18 AM
Cap'n Krusty ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,794 Joined: 24-June 04 From: Santa Maria, CA Member No.: 2,246 Region Association: Central California |
"Brake bands" aren't "syncros" They're the little curved pieces that transfer pressure inside the syncro rings. If they're not beat up at the ends, they're probably OK. If you decide to change them, do 'em in pairs, and be sure you have the right style. Early components (the whole set of 4 pieces) differ from the improved later versions, and you CANNOT mix-n-match. First gear syncro internals are different from the 2/3/4/5 internals.
The Cap'n |
Lo-Fi Version | Time is now: 15th April 2026 - 12:47 AM |
