H4 headlight relay question |
SKL1 |
Jul 3 2014, 01:22 PM
Senior Member Group: Members Posts: 1,602 Joined: 19-February 11 From: north Scottsdale Member No.: 12,732 Region Association: Upper MidWest |
Putting in new H4 headlights with the 100W high beam and utilizing the "relay" to protect the OEM wiring.
Using the relay and new lights from Pelican and have checked and rechecked my wiring several times. Fused power from battery to #30. #85 to ground. #87 to high beam terminal of each light, #86 to old headlight wiring on one side, and taped off the other as recommended. I have 12V into relay when high beams are on, and good 12V from battery, but neither high beam works thru the system, though low beams work. Fuses all good- new JWest fuse panel. Bulbs new and work fine when bench tested. Any ideas???? Have 2 new relays from Pelican and have tried both... ('73 2.0) |
SKL1 |
Jul 4 2014, 02:40 PM
This car will spend its life in AZ- it is VERY dark there at night as they don't believe in street lights etc. I need the 100W high beams!!
I see JWest has a early 911 relay kit- gonna see if that may work too... |
Lo-Fi Version | Time is now: 18th May 2024 - 06:16 AM |
