| ben*james |
Jul 3 2014, 05:43 PM
LIFER ![]() ![]() ![]() Group: Members Posts: 525 Joined: 16-February 09 From: Portland Oregon Member No.: 10,062 Region Association: Pacific Northwest
Seems to be getting worse and worse. Brake lever fully depressed. Pretty sure it's hitting the little button. After a few miles and bumps I have to pull over and set then release the break to stop the blink. I'm thinking about cutting the wires but I should probably fix it correctly (IMG:style_emoticons/default/smile.gif)
| Spoke |
Jul 3 2014, 05:51 PM
Jerry ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,373 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None
Sounds like you need a bit of an adjustment.
I had to glue a little piece of plastic to the handle to fully depress the switch. |
| toolguy |
Jul 3 2014, 07:04 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,276 Joined: 2-April 11 From: San Diego / El Cajon Member No.: 12,889 Region Association: Southern California
1 screw and it pulls out. . then look at the contacts. . new ones are available at the dealer . same part as the door light switch . it's now a 944 part number but works fine. .
Lo-Fi Version | Time is now: 12th April 2026 - 02:28 PM |
