Carburetor Fine Tuning, Trying to get my dual EMPI HPMX 44's as close to perfect as possible - Now running Spanish Weber 48 IDF's... |
sgetsiv |
Jul 6 2014, 08:26 PM
Former 914 Owner :( Group: Members Posts: 159 Joined: 20-June 08 From: Portland, OR Member No.: 9,192 Region Association: Pacific Northwest |
I've been working on my carbs for the past few weeks to try and get them to run as close to perfect as possible. Here are the details at this point:
2315 Raby built engine EMPI HPMX Dual 44's 52 idle jets 150 main jets 200 air correction jets 55 accelerator pump jets New CB Performance Rotary Fuel Pump - 3.5 psi - stock location No fuel pressure regulator - just a TEE fitting Stack electrical fuel pressure gauge 0-15 psi - reads 3.1 psi when cold, 2.4 psi once everything warms up and is running Wide band AFR gauge Fuel lines flushed and fuel filters cleaned Gas tank pulled and re-installed lines at base to be sure there are no kinks I rebuilt the carbs with the EMPI rebuild kits which includes all new gaskets, accelerator pump diaphragm, new mini fuel filter, new float needle valve assembly, new washers for the accelerator pump jets, new o-rings for the idle jets and idle mixture screws. Floats are set to factory specifications as well. I pulled the throttle plates and was extremely careful to be sure I put them back exactly the same way and that they do not hang up - their action is perfect and they cover the progression holes. This project started a few weeks ago after running into lean issues under load - turned out to be the fuel pump relay was going bad. There was a significant voltage drop across the relay and it finally ended up failing completely during testing. Once the engine is fully warmed up, my AFR is reading 12 to 13 at idle; adjusting the idle mixture screws can make a big difference in AFR readings without changing the idle significantly. I started out with the accelerator pump jets set to factory setting of 7mm of thread exposed. During my test drives today, I turned them in (richer) to about 10mm. Response is better but still not perfect. I'm getting AFR readings in the 12-14 range during "regular driving" on the highway. Going up hill under load at 60-70 mph in 4th gear (say around 3500-3800 rpm) and very slowly pushing on the throttle creates a lean condition. Once I step on it, the AFR drops down to 11-12 and then settles again in the 12-14 range. I would really appreciate some input on adjusting the accelerator pump and any other suggestions on how to get the most of these carbs. Are the accelerator pump jets (55) big enough? They can certainly be reamed out. I did measure the output and got around 0.3 ml fairly consistently for each jet. All 4 jets spray straight right into the center of the carb in an even stream. |
72hardtop |
Aug 10 2014, 01:49 PM
Member Group: Members Posts: 120 Joined: 11-September 13 From: Seattle/HB Ca./Fujieda-Japan Member No.: 16,378 Region Association: Pacific Northwest |
You want to actually see how well you have the jetting? Remove you main jet stacks (all of it) and drive around on the idle jets only for a couple days. This will absolutely tell you when and where the idle jets fall on their face. Once that's done go a larger size or two on the mains and start adjusting the mains down.
Don't be surprised if you find you need a 47.5 idle at or near sea level. Are you using an LM-2? |
sgetsiv |
Aug 10 2014, 04:34 PM
Lo-Fi Version | Time is now: 22nd May 2024 - 04:40 PM |
