QUOTE(Chris914n6 @ Aug 6 2014, 12:20 AM)
QUOTE(larss @ Aug 4 2014, 09:58 PM)
QUOTE(Chris914n6 @ Aug 4 2014, 09:50 PM)
...I have a blower that doesn't work on the middle setting, luckily it's not a dead short.
All speeds should be possible to engage but I think you can find a small spot on the control arm movement between every speed setting where the fan goes off on these type of controls...this is to prevent engaging two speeds at the same time...this is how mine seems to work...
/Lars S
That's true, but mines sitting on the floor where I was doing airflow testing for my ac kit <-- shameless plug (IMG:
style_emoticons/default/smile.gif)
Blower resistors fail fairly often. I've done my share as a mechanic.
i may recheck that at some point but right now i want to test a different control unit because ive had 2 fan boxes installed and they both acted the same way - so my thought is to test a different controller/sliders one that tested fine in another vehicle-
btw- i want to be put on the list for that A/C box, i was reading your thread on that and it seems like it might be a bit of work but worth it for those of us in the south!
- there is another member that had put together a mount etc too i think and is using a newer a/c compressor that will draw much less drain on the motor- i just dont know about running the a/c lines etc. -
any way i digress--- i need to test a different controller --
