Seat tracks |
Seat tracks |
Harpo |
Jul 15 2014, 04:13 PM
Senior Member Group: Members Posts: 1,304 Joined: 21-August 11 From: Motor City aka Detroit Member No.: 13,469 Region Association: None |
When I got my seats reupholstered I removed the seat tracks cleaned them up and painted (outside only). I also cleaned up my seat frames & painted them as well.
I can't get them to go back together. Is there some trick? Thanks David |
bdstone914 |
Jul 15 2014, 04:25 PM
bdstone914 Group: Members Posts: 4,523 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
When I got my seats reupholstered I removed the seat tracks cleaned them up and painted (outside only). I also cleaned up my seat frames & painted them as well. I can't get them to go back together. Is there some trick? Thanks David Remove the seat frame from the car. Lossen the Allen screws that hold the rails to the seat. Try sliding the frame onto the rails. They are probably slightly mus aligned. Slide the frame back to get to two of the screws and re tighten them. Grease the rails too. Aren't you a hardware engineer? (IMG:style_emoticons/default/poke.gif) Bruce |
Harpo |
Jul 15 2014, 06:44 PM
Thanks Bruce. I only deal with the chassis stuff not this silly stuff @ work
Lo-Fi Version | Time is now: 21st May 2024 - 02:12 PM |
