74 1.8 L-Jet No Run - Help Please!, No fuel out of injectors |
SteveL |
Jul 18 2014, 10:26 PM
Senior Member Group: Members Posts: 658 Joined: 7-August 03 From: Andover, MN Member No.: 991 Region Association: None |
74 1.8 with L-Jet
- Gas in tank - Key on and AFM flap moved with screwdriver, I can hear the pump run. - Removed fuel injector and placed in jar. Key on, moved AFM flap (can hear pump running), no fuel. Reconnected AFM to air intake and cranked it over (can't hear pump over starter), still no fuel in jar. Propped the AFM flap open, key on (can hear pump running), cranked it over, still no fuel in jar. Best I can figure, I think it must be one of the following: - plugged fuel filter? - fuel pump spinning, but not actually pumping fuel? - fuel pressure regulator? - injectors not receiving signal to spray? (IMG:style_emoticons/default/WTF.gif) Any suggestions? Thanks |
JeffBowlsby |
Jul 18 2014, 11:24 PM
914 Wiring Harnesses Group: Members Posts: 8,510 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
All wires on the resistor pack intact?
Lo-Fi Version | Time is now: 17th May 2024 - 08:22 PM |
