WTB 914 Tie Rod End Boots, Tie Rod End Boot |
doit2xs |
Jul 19 2014, 04:21 PM
Newbie Group: Members Posts: 20 Joined: 15-February 06 From: Mascotte, Florida Member No.: 5,588 Region Association: None |
Hi, does anyone have to sell or know where to buy just the tie rod end boots?
Thanks, Don |
Tom_T |
Jul 19 2014, 06:02 PM
IIRC it's the same steering rack as the 911/912/930 of that era, so the boots should also be the same -
....but maybe someone else more up to speed on it can confirm that??? If so, then Porsche dealers &/or Porsche Classic, plus maybe Mikey914 & PMB & Sierra Madre & other vendors on here, Stoddards in OH & Einmalig in CA & AutoAtlanta in GA area all likely sources. You'll probably also need new cir-clips (4 fasteners - 2 each side & 1 each end of the boot) for the ends, since aftermarket screw-type bands put too much pressure below the screw device & deform the seal - letting dust & water inside. Those may be harder, but possible at those same sources. |
bdstone914 |
Jul 19 2014, 06:41 PM
bdstone914 Group: Members Posts: 4,507 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
Sounds like you need the outer tie rod boots. I do not know of a source for them. I think Tom was describing the steering rack boots that go on the inner tie rod ends.
euro911 |
Jul 19 2014, 11:14 PM
Retired & living the dream. God help me if I wake up! Group: Members Posts: 8,845 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California |
Arizona Autohaus ... azautohaus.com
bdstone914 |
Jul 19 2014, 11:35 PM
euro911 |
Jul 20 2014, 11:25 AM
93034719102 Rack & Pinion Boot; Left/Right $10.88 ea.
Click here my friends (IMG:style_emoticons/default/biggrin.gif) |
bdstone914 |
Jul 20 2014, 11:32 AM
93034719102 Rack & Pinion Boot; Left/Right $10.88 ea. Click here my friends (IMG:style_emoticons/default/biggrin.gif) As he said tie rod boot Not rack and pinion. |
euro911 |
Jul 20 2014, 12:38 PM
And what, pray tell, is the difference ?
The tie rods connect to the ends of the rack and pinion shaft. The boots cover the same joint, so whether they're call 'tie rod' boots or 'rack & pinion' boots is irrelevant. Educate me (IMG:style_emoticons/default/confused24.gif) EDIT: If you need to replace the rubber cover ('boot' ?) on the outer end of the tie rod, it's time for a new tie rod end, not a boot Oh God ... I'm becoming Krusty (IMG:style_emoticons/default/headbang.gif) |
doit2xs |
Jul 20 2014, 02:18 PM
Hi, I replaced everything with the kit in the pic in 2006-07. Car sat till now, all boots look like they are 60 years old. 1200 miles was put on car after installing so everything is tight. Just need new boots. Called Automobile Atlanta ordered rack boots only they said no tie rod boots. What they sent was rack boots for stock tie rod setup. Looks like it will not work. So no one sells just the boots for the turbo Tie Rods?
Thanks Guys |
914Sixer |
Jul 20 2014, 02:39 PM
914 Guru Group: Members Posts: 8,863 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Try looking up VW Bug boots. They should be the same size I think. EIS Parts has them for $4.
euro911 |
Jul 20 2014, 03:43 PM
... So no one sells just the boots for the turbo Tie Rods? (IMG:style_emoticons/default/confused24.gif) Revisit post #6 above and click on the link. These are the boots for the Lemforder turbo tie rods (or steering rack boots, whatever one wishes to call them). I guess other places sell boots, but I bought the same Lemforder boots last year when I bought a set of turbo tie rods from them (the boots are sold separately). |
orthobiz |
Jul 20 2014, 03:46 PM
Senior Member Group: Members Posts: 1,754 Joined: 8-January 07 From: Cadillac, Michigan Member No.: 7,438 Region Association: Upper MidWest |
Revisit post #6 above and click on the link. These are the boots for the Lemforder turbo tie rods (or steering rack boots, whatever one wishes to call them). I guess other places sell boots, but I bought the same Lemforder boots last year when I bought a set of turbo tie rods from them (the boots are sold separately). Plus they're on sale 45 cents off. Just sayin'. P |
euro911 |
Jul 20 2014, 05:13 PM
They were $12.42 when I bought them ... I should have waited, huh?
(IMG:style_emoticons/default/laugh.gif) |
euro911 |
Jul 20 2014, 05:14 PM
(IMG:style_emoticons/default/laugh.gif) EDIT: WTF I made another double post? Oh well, I did buy two of them, so ... |
Tom_T |
Jul 21 2014, 12:54 PM
And what, pray tell, is the difference ? The tie rods connect to the ends of the rack and pinion shaft. The boots cover the same joint, so whether they're call 'tie rod' boots or 'rack & pinion' boots is irrelevant. Educate me (IMG:style_emoticons/default/confused24.gif) EDIT: If you need to replace the rubber cover ('boot' ?) on the outer end of the tie rod, it's time for a new tie rod end, not a boot Oh God ... I'm becoming Krusty (IMG:style_emoticons/default/headbang.gif) Yes, that's the one in the pic I was thinking he meant. Maybe Bruce it talking about that small blue or white cover over the tie-rod end, which I thought was just for shipping protection? Although I don't see how the recently replaced boots on the newer tie-rods could be trash now just sitting, unless it was made from inferior rubber from an aftermarket supplier, or using the wrong end clips as I cautioned above, or hitting a rock or tire-bumper etc.!!?? (IMG:style_emoticons/default/confused24.gif) BTW - There were 2 gorgeous 914s in the PAC LA Region's concours at Santa Monica airport's Air Museum yesterday where I was judging....a 1970 original 6 in Phoenix Red/Black & a `73 914-2.0 in Delphi Green Met/Beige!!! (IMG:style_emoticons/default/drooley.gif) Carrerra GT, new Macan Turbo, many really nice classics & new ones .... Porsches + Planes - great combo!! (IMG:style_emoticons/default/wub.gif) ...anyway, I digress, but Mark & OP are LA guys! Cheers! (IMG:style_emoticons/default/beerchug.gif) |
bdstone914 |
Jul 21 2014, 03:09 PM
We're the tie rod boots from Hamburg Teknik? I have heard nothing good about their products.
Yes I thought that is what he wanted, the small boots that go on the outer tie rod ends. But at $12 for a complete German tie rod why not replace the whole tie rod end? |
doit2xs |
Jul 23 2014, 07:52 AM
Does anyone know witch factory rack boot goes on witch side? There is a long one with a clamp on each end and a short one with a clamp only on the outside.
Also has anyone used factory rack boots with the Turbo Tie rods? Thanks, Don |
bdstone914 |
Jul 23 2014, 08:12 AM
Does anyone know witch factory rack boot goes on witch side? There is a long one with a clamp on each end and a short one with a clamp only on the outside. Also has anyone used factory rack boots with the Turbo Tie rods? Thanks, Don The left and right boots are the same. Get the right boots. They are different for a reason. Who knows what AA might have sent. Look at post #6 Mark gave you the link. |
doit2xs |
Jul 23 2014, 01:51 PM
Ok, AA sent rack boots for a Porsche 924/944. So they got to go back.java script:emoticon(':headbang:','smid_31')
So if you have Turbo Tie Rods do you need special boots? Thanks |
bdstone914 |
Jul 23 2014, 02:14 PM
Lo-Fi Version | Time is now: 18th April 2024 - 04:59 PM |
