Mixture always too rich- weber 44 idf's |
tornik550 |
Jul 21 2014, 04:42 PM
Senior Member Group: Members Posts: 1,248 Joined: 29-January 07 From: Ohio Member No.: 7,486 Region Association: None |
I have dual weber 44 idf's on my 2258. I was having a problem with one of my cylinders and found that the main circuit had some sort of black booger plugging most of the main circuit of cyl 2 and a small on in cyl 3. I completely cleaned everything and reassembled. The car is driving way better. I set the floats at 11.5 without the gasket.
Now I am having the other problem- my car is always too rich. At idle my a/f ratio is 13:1 which is ok for me. If I try to lean it out any more then I get popping on decel at low rpm's. On the main circuit, I am using 125 mains, f11 et, 210 ac and I am consistently around 10.2:1. I can but smaller mains but it seems like I shouldn't need that small of mains. My setup- idles-50 mains-125 et-f11 ac- 210 vents- 34 Any ideas of how to lean the main circuit? |
tornik550 |
Jul 22 2014, 03:05 PM
I decreased the size of my vents to 32 and the car seemed to respond we however my A/f ratios are still off. The other things that I noticed is that with larger vents, if I leaned out the carbs too much- I would get a pop on decel. Now it seems to pop earlier than it did with larger vents. I do not think this is a exhaust leak cause it does go away if I richen the condition slightly. I have also checked with a fog machine and didn't see a leak.
Also- some things that I forgot to mention is that I have 1 5/8 inch headers with a triad exhaust. The car is mainly used for spirited street driving. It seems like most of my driving is done older 3500rpm. I have a very wide variety of jets, vents, et. however the smallest mains that I have is 125 however I have ordered a bunch more so I will have smaller options soon. |
Lo-Fi Version | Time is now: 17th May 2024 - 04:00 PM |
