Cleaning a Transaxle |
Larmo63 |
Jul 22 2014, 10:15 PM
I'm pulling the trans for the new clutch install, etc. and I'd like to clean all of the black (tar?) gunk off of my transmission. What are the recommendations here? Dip it? Degreaser and manpower? I'm doing new cable, fluid too, so.....?
Ideas? Experience? Is my tranny supposed to have all that black shit all over it? |
Mike Bellis |
Jul 22 2014, 10:31 PM
Dollar Tree has "Awesome" cleaner & degreaser. Yellow color, in bottles. It works awesome!
dangrouche |
Jul 22 2014, 10:36 PM
dangrouche Group: Members Posts: 550 Joined: 1-May 04 From: San Francisco Bay Area Member No.: 2,012 Region Association: None |
people have said that purple cleaner available at hardware stores or FLAPs. i personally have used gasoline in a tub with a stiff bristle brush. scraped at it with plastic putty knife. did it in the shade, outdoors. DO NOT soak it and forget it. Basically a sponge bath.
bdstone914 |
bdstone914 Group: Members Posts: 4,512 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
I'm pulling the trans for the new clutch install, etc. and I'd like to clean all of the black (tar?) gunk off of my transmission. What are the recommendations here? Dip it? Degreaser and manpower? I'm doing new cable, fluid too, so.....? Ideas? Experience? Is my tranny supposed to have all that black shit all over it? I have used E Z off oven cleaner on the hard deposits. Don't dip it. Cover the vent on top. |
Eric_Shea |
Jul 22 2014, 10:46 PM
PMB Performance Group: Admin Posts: 19,274 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
I wouldn't use "any" of that stuff without testing it on "magnesium".
Engine and oven degreasers will pit the mag almost instantly. Google is a great tool. Check for ways to clean magnesium. Gots ta be careful. |
toolguy |
Jul 22 2014, 10:51 PM
Don't use EZ OFF on Aluminum or Magnesium. . it eats into the surface and causes pits and dark discoloration. . l. .
Gasoline works great for the heavy deposits, over a drip pan, and out in the driveway in pleanty of fresh air. . use a water soluble cleaner for the final cleaning so you can wash it off with soap and water and a hose. . |
Eric_Shea |
Jul 22 2014, 10:54 PM
TheCabinetmaker |
Jul 23 2014, 04:15 AM
I use a brass wire wheel on a right angle drill. I buy them in a package with several sizes and shapes. The soft brass will remove the gunk without damaging the surface. Bout an hour and I'm done. No chemicals.
Porschef |
Jul 23 2014, 05:40 AM
How you doin' Group: Members Posts: 2,165 Joined: 7-September 10 From: LawnGuyland Member No.: 12,152 Region Association: North East States |
Kerosene. And a stiff brush, just baste the tranny in a large enough tray/container. Finish up with a mild degreaser.
Dr Evil |
Jul 23 2014, 12:15 PM
Send me your transmission! Group: Members Posts: 22,993 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region |
For those of you worried about Ez-off and mag, relax. I did a study on this and posted it around 2006-7 IIRC. I have access to lost of parts and left the EZ-off on an intermediate plate for weeks. No change. No erosion.
However, some of the other options may be better cleaners. I have no data to back it up, but I can research this in the future as it seems like valuable info. |
Drums66 |
Jul 23 2014, 01:30 PM
Don't use EZ OFF on Aluminum or Magnesium. . it eats into the surface and causes pits and dark discoloration. . l. . Gasoline works great for the heavy deposits, over a drip pan, and out in the driveway in pleanty of fresh air. . use a water soluble cleaner for the final cleaning so you can wash it off with soap and water and a hose. . .......Ya..with a good "citrus"cleaner.....& no wire brushes! (IMG:style_emoticons/default/stones.gif) (IMG:style_emoticons/default/thumb3d.gif) (IMG:style_emoticons/default/flag.gif) (IMG:style_emoticons/default/bye1.gif)(gasoline works wonder's)but I prefer "CITRUS" |
worn |
Jul 23 2014, 02:23 PM
can't remember Group: Members Posts: 3,145 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest |
I'm pulling the trans for the new clutch install, etc. and I'd like to clean all of the black (tar?) gunk off of my transmission. What are the recommendations here? Dip it? Degreaser and manpower? I'm doing new cable, fluid too, so.....? Ideas? Experience? Is my tranny supposed to have all that black shit all over it? First, I had no problem with oven cleaner. Leave it in a 55 gallon drum for a couple of weeks and it could be a real problem though. The issue is time and quantity. Second, it is hard nasty work. I prefer chlorinated brake cleaner. I work in toxicology and I can tell you it isn't good for you. On the other hand it takes no prisoners and as Mr Sparkle says, it disrespects dirt. Anything oily and cleaner than your gunk will work as a substitute. Detergents act as sort of oils, but have the advantage of bonding to water too. Pure dishwasher soap is good too. I like Dawn. I buy 3-packs. Third. The wire brush. Dremel brushes and bigger spinning brushes actually get the dirt off when the oil is gone. WARNING: spinning wire brushes loose their bristles like arrows. I have pulled a dremel bristle that pierced my nose straight on. Note the proximity to the eyes. I had goggles on. Finally. Paint it! Magnesium very badly wants to combine with oxygen and return to the earth. Note the erosion already present on the case. I have had excellent results with grey epoxy DP-50 covered with clear coat to protect the epoxy from UV. I am doing my third case right now. These trannys are fun to work with and pretty straightforward once you have made some mistakes. (IMG:style_emoticons/default/MDB2.gif) |
'72914guy |
Jul 23 2014, 03:38 PM
Newbie Group: Members Posts: 10 Joined: 26-April 08 From: SoCal Member No.: 8,969 Region Association: Southern California |
You could try going to a do it yourself car wash, and use hot and soapy water with the pressure washer. That should get a lot of the gunk of the tranny, and the engine too.
cpavlenko |
Jul 23 2014, 03:42 PM
Member Group: Members Posts: 489 Joined: 19-April 12 From: North Arizona Member No.: 14,400 Region Association: Southwest Region |
I use simple green, let it soak in, might take a couple soaking. Great stuff, and by degradable product.
Drums66 |
Jul 23 2014, 04:09 PM
....Simple green,is another good cleaner! I 2nd (IMG:style_emoticons/default/idea.gif)
(IMG:style_emoticons/default/stones.gif) (IMG:style_emoticons/default/tunez.gif) (IMG:style_emoticons/default/popcorn[1].gif) (IMG:style_emoticons/default/bye1.gif) |
Jul 23 2014, 06:11 PM
Finally. Paint it! Magnesium very badly wants to combine with oxygen and return to the earth. IIRC, the alloy used in the trans cases (and in mag case engines) is one of the ones where the metal forms a "sacrificial layer" of oxidation on the outside, and then stops. The layer keeps new metal from being exposed to oxygen, so nothing else oxidizes. So painting is not necessary. In fact, if you like to slop paint on really thick, you might actually impede the cooling of the trans! If it's bad enough, it might even be enough to notice--in racing conditions... (IMG:style_emoticons/default/wink.gif) --DD |
Jeffs9146 |
Jul 23 2014, 06:23 PM
Dollar Tree has "Awesome" cleaner & degreaser. Yellow color, in bottles. It works awesome! (IMG:style_emoticons/default/agree.gif) That stuff is totaly AWSOME!! I spray it on, massage it with a wire brush and rinse it off! Grease and Oil just wash away! |
Dr Evil |
Jul 23 2014, 06:25 PM
Finally. Paint it! Magnesium very badly wants to combine with oxygen and return to the earth. IIRC, the alloy used in the trans cases (and in mag case engines) is one of the ones where the metal forms a "sacrificial layer" of oxidation on the outside, and then stops. The layer keeps new metal from being exposed to oxygen, so nothing else oxidizes. So painting is not necessary. In fact, if you like to slop paint on really thick, you might actually impede the cooling of the trans! If it's bad enough, it might even be enough to notice--in racing conditions... (IMG:style_emoticons/default/wink.gif) --DD I would have to disagree with this. The Mag will suffer exfoliating oxidation as seen in wet and salt road climates. In CA not as bad, but on the East, and other parts of the country you want protection. They covered them from the factory for a reason. |
Mike D. |
Jul 23 2014, 06:50 PM
OK, It runs now, and pretty good too! Group: Members Posts: 1,445 Joined: 3-January 03 From: Santa Clarita, Ca Member No.: 85 Region Association: None |
Finally. Paint it! Magnesium very badly wants to combine with oxygen and return to the earth. IIRC, the alloy used in the trans cases (and in mag case engines) is one of the ones where the metal forms a "sacrificial layer" of oxidation on the outside, and then stops. The layer keeps new metal from being exposed to oxygen, so nothing else oxidizes. So painting is not necessary. In fact, if you like to slop paint on really thick, you might actually impede the cooling of the trans! If it's bad enough, it might even be enough to notice--in racing conditions... (IMG:style_emoticons/default/wink.gif) --DD We have found that after cleaning, soak the mag case diesel fuel. The diesel has enough oil to find it's way into the Mag and stop the oxidizing. Rinse and let dry, there is still plenty of oil in pores of the metal. Or clean and spray with WD-40... |
worn |
Jul 23 2014, 09:19 PM
Finally. Paint it! Magnesium very badly wants to combine with oxygen and return to the earth. IIRC, the alloy used in the trans cases (and in mag case engines) is one of the ones where the metal forms a "sacrificial layer" of oxidation on the outside, and then stops. The layer keeps new metal from being exposed to oxygen, so nothing else oxidizes. So painting is not necessary. In fact, if you like to slop paint on really thick, you might actually impede the cooling of the trans! If it's bad enough, it might even be enough to notice--in racing conditions... (IMG:style_emoticons/default/wink.gif) --DD That is an interesting thought. I still see plenty of very pure magnesium oxide all over the place though. And insee regions of case erosion, so in some environments corrosion is a problem. If we baby the cars as we probably will, that should largely halt. Physicists would say that if you want to lose heat fast and paint, then use black. Compromise? (IMG:style_emoticons/default/beerchug.gif) |
Lo-Fi Version | Time is now: 23rd April 2024 - 06:54 AM |
