> 914World Classifieds Rules
> WTB Front 5 lug hubs
Alapone
post Jul 23 2014, 06:00 AM
I recently purchased a set of 1974 911 boge struts. Need to buy front hubs with lugs and backing plate.
Also anybody have rear 5x130 drilled 914-4 rotors? need those too.
Thanks.
euro911
post Jul 23 2014, 01:27 PM
I have a pair of brand new 5-lug rear rotors from PMB that I won't be using since I decided to stay with ATS Classics 4-lug wheels.
$150. shipped (CONUS)
bdstone914
post Jul 23 2014, 02:19 PM
bdstone914
QUOTE(euro911 @ Jul 23 2014, 12:27 PM) *
Good price on the rotors but be aware that the true 914-6 rotors have the two screw holes for in a different location then the 914 rotors. If they are redrilled 914 rotors the holes line up.
bdstone914
post Jul 23 2014, 06:18 PM
bdstone914
QUOTE(bdstone914 @ Jul 23 2014, 01:19 PM) *
I do have a pair of 911 backing plates that were powder coated satin black. I think the cut out is for m calipers. If you are running S or A calipers they would need to be trimmed.
Asking $50 for the pair shipped.
Alapone
post Jul 24 2014, 05:19 AM
QUOTE(euro911 @ Jul 23 2014, 03:27 PM) *
are these originally 914-4 rotors that were drilled? I will be running redrilled 4 lug hubs in the rear.
euro911
post Jul 24 2014, 03:26 PM
Yes.
Alapone
post Aug 5 2014, 05:56 AM
Still looking for these if anyone can help.
mskala
post Aug 5 2014, 06:30 AM
R
QUOTE(Alapone @ Aug 5 2014, 07:56 AM) *
I have a pair of fronts with lugs that you can have for shipping cost. Basically
they came off my -6 when I was trying to fix another issue and I noticed after
cleaning that the anodizing in some of the recessed areas is coming off and
starting to get pitting. They will work fine but at some point need to be
protected from more corrosion. PM me for photos if interested.
bdstone914
post Aug 5 2014, 06:39 AM
bdstone914
QUOTE(mskala @ Aug 5 2014, 05:30 AM) *
I don't think the hubs from a 6 will fit the 74 struts he has. Yours fit on 16 mm spindles and you ones he needs for on 18 mm spindles.
mskala
post Aug 5 2014, 08:00 AM
R
QUOTE(bdstone914 @ Aug 5 2014, 08:39 AM) *
I'm fairly sure that all the 911 struts of that time window are the same in the
bearing taper area. Will try to double-check later.
johnhora
post Aug 5 2014, 12:44 PM
I have a pair front hubs from a 73' 911 available
johnhora
post Aug 6 2014, 12:27 PM
Alapone...
sent you a pm but just noticed in your post the struts you have are from a 74'....
what I have are two hubs from 74-89' 911 part no 911.341.605.4R
I also have the bearings and stock 45mm studs
$80 for all shipped USA48
Thanks...john
Attached Image Attached ImageAttached Image
Alapone
post Aug 12 2014, 11:40 AM
I was able to get a set of these thanks for the help guys.
brant
post Aug 12 2014, 06:54 PM
John. I'm interested if still available
euro911
post Aug 15 2014, 04:42 AM
So did the rear rotors meet your expectations, Andrew?
(inquiring minds ...) (IMG:style_emoticons/default/popcorn[1].gif)
- Lo-Fi Version Time is now: 16th April 2024 - 05:35 AM
