Question about Media Blasting and Compressors, Which is the correct combination? |
ellisor3 |
Jul 23 2014, 09:28 AM
HPWhore Group: Members Posts: 811 Joined: 23-October 08 From: Fleming Island, Florida Member No.: 9,683 Region Association: South East States |
I recently bought a media cabinet and I already had a 30 gallon compressor. I started a trial run with the cabinet on a pair of calipers. I got no where. The media barely put a dent in the caliper paint. I sprayed for 30 minutes and completed an area about 3"x3". The media was glass bead 70 grit and the compressor was set at 100 psi.
I believe my issue may be the amount of air the compressor moves, and not the PSI. What is the recommended amount that will work on brake calipers? My compressor is a 5.2 CFM. Is glass bead appropriate for enamel paint? What size compressor do I need? What is everyone else using? |
CptTripps |
Jul 23 2014, 09:47 AM
:: Punch and Pie :: Group: Members Posts: 3,584 Joined: 26-December 04 From: Mentor, OH Member No.: 3,342 Region Association: Upper MidWest |
Are you sure you are using the right media? What is the pressure set at?
Mine is a HF 21gal that only kicks out about 4CFM and I can blast the shit out of stuff...in short bursts |
ellisor3 |
Jul 23 2014, 10:52 AM
Are you sure you are using the right media? What is the pressure set at? Mine is a HF 21gal that only kicks out about 4CFM and I can blast the shit out of stuff...in short bursts I have Aluminum Oxide as well as glass bead, and neither seem to work all that well. The pressure has been set a 60, 80 and 100 without much results. |
Lo-Fi Version | Time is now: 14th May 2024 - 01:48 PM |
