Question about Media Blasting and Compressors, Which is the correct combination? |
ellisor3 |
Jul 23 2014, 09:28 AM
HPWhore Group: Members Posts: 811 Joined: 23-October 08 From: Fleming Island, Florida Member No.: 9,683 Region Association: South East States |
I recently bought a media cabinet and I already had a 30 gallon compressor. I started a trial run with the cabinet on a pair of calipers. I got no where. The media barely put a dent in the caliper paint. I sprayed for 30 minutes and completed an area about 3"x3". The media was glass bead 70 grit and the compressor was set at 100 psi.
I believe my issue may be the amount of air the compressor moves, and not the PSI. What is the recommended amount that will work on brake calipers? My compressor is a 5.2 CFM. Is glass bead appropriate for enamel paint? What size compressor do I need? What is everyone else using? |
cpavlenko |
Jul 23 2014, 03:46 PM
Member Group: Members Posts: 489 Joined: 19-April 12 From: North Arizona Member No.: 14,400 Region Association: Southwest Region |
Try 180 A.O., That's what I use. Leaves a nice finish. (Aluminum Oxide)
Lo-Fi Version | Time is now: 14th May 2024 - 01:14 PM |
