Question about Media Blasting and Compressors, Which is the correct combination? |
ellisor3 |
Jul 23 2014, 09:28 AM
HPWhore Group: Members Posts: 811 Joined: 23-October 08 From: Fleming Island, Florida Member No.: 9,683 Region Association: South East States |
I recently bought a media cabinet and I already had a 30 gallon compressor. I started a trial run with the cabinet on a pair of calipers. I got no where. The media barely put a dent in the caliper paint. I sprayed for 30 minutes and completed an area about 3"x3". The media was glass bead 70 grit and the compressor was set at 100 psi.
I believe my issue may be the amount of air the compressor moves, and not the PSI. What is the recommended amount that will work on brake calipers? My compressor is a 5.2 CFM. Is glass bead appropriate for enamel paint? What size compressor do I need? What is everyone else using? |
dan_the _body_guy |
Jul 26 2014, 04:20 AM
Newbie Group: Members Posts: 28 Joined: 1-April 14 From: cleveland ohio Member No.: 17,185 Region Association: None |
are we 100% sure its enamel paint and not powdercoating youre attempting to strip? enamel paint is fairly soft and should blast off pretty quick with just about any media. it sounds like powdercoating youre fighting against. try hitting it with a torch to burn the coating then blast it off with a course garnet
Lo-Fi Version | Time is now: 14th May 2024 - 03:23 PM |
