Mystery 340 cam, Mystery cam in 1911 teardown |
lonewolfe |
Jul 23 2014, 02:51 PM
Senior Member Group: Members Posts: 819 Joined: 12-September 11 From: Oakland, CA Member No.: 13,549 Region Association: Northern California |
I have a 1911cc motor I'm tearing down. It has a camshaft that is stamped 340 on the end. Are any of you familiar with this cam? It has a bolt on cam gear so I know it's an aftermarket cam but I have no information on the engine build from the previous owner. The engine has stock Q heads opened up for the larger 96.0mm cylinders but has stock size valves.
Anyone? |
Jeff Hail |
Jul 23 2014, 09:07 PM
Senior Member Group: Members Posts: 1,141 Joined: 3-May 07 From: LA/ CA Member No.: 7,712 |
I have a 1911cc motor I'm tearing down. It has a camshaft that is stamped 340 on the end. Are any of you familiar with this cam? It has a bolt on cam gear so I know it's an aftermarket cam but I have no information on the engine build from the previous owner. The engine has stock Q heads opened up for the larger 96.0mm cylinders but has stock size valves. Anyone? Sounds like a WEB or Elgin is my guess. |
Lo-Fi Version | Time is now: 28th March 2024 - 04:38 AM |
