Under cowl A/C unit design input thread and gauging interest, replacing behr with burrr! |
Chris914n6 |
Jul 23 2014, 08:24 PM
Jackstands are my life. Group: Members Posts: 3,320 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
Dusted off another one of my projects from when I first built my waterpumper. Heater and A/C replacing the factory fresh air blower unit.
History. I built the unit using a tube/fin core from my Uncle's buddy Dave @ Hotrod Air. HRA went under in the recession and so did the company that actually made the cores. Oddly enough this is a benefit despite having made some really nice wood vacuum forming bucks. The good news. For version 2 I went with separate heater and evap cores. The heater is off the shelf, I just need to trim the tubes. The evap I'm having made by a company I met at the 2013 SEMA show and is modern plate type. Blower is a 3 speed. The nitty gritty. Uses stock controls and stock air deflector boxes. Hoses run Pass side like DPD/VPC. I did design a setup for modern controls and deflector boxes with a separate side vent path, but it's a bit complicated to make. I have plans to offer 3 versions. Model B - A/C and heat for us waterpumpers. Runs recirc through the heater tube holes so no cutting. Unit is too tight of a fit for fresh air. I'll have an optional drainage piece for those that don't seal the grill. Model A - A/C only for aircooled cars. Because the heater tube holes are being used for heat, air intake will be from the grill opening. You could cut a 2.5" hole in the cowl for recirc instead if you wanted or use just one heat exchanger. Model H - Heater only for waterpumpers. Same unit as the A/C only except that recirc is possible through the heater hose holes OR model B with no evap, haven't decided yet. In the kit - Main unit, mounting brackets, air hoses & clamps, blower wiring, expansion valve, instructions. Options - Cabin filter. Grill water drain. The other pieces... Condensers- it depends on the radiator you using and what you can make fit, no point in me trying to keep an inventory. The exception could be a replacement to the DPD/VPC Condenser unit for air-cooled cars, I haven't gotten past doodles yet. Receiver-driers of the universal type can be had on Ebay for under $15 shipped, I'll pick one out for you, same with the pressure switch. Hoses, too many variations and too much overhead for me, but Vegas has 3 places that will build them on your car so I assume that's practically everywhere. Prices trend $100-$150. Hard lines- Research has spec'd it as 6063 aluminum. DPD/VPC used hard lines along the rocker and up the wheel wells. Heater hose- nothing special about it but it's long and 5/8"ID. Prices... about the same as the Hotrod kits. Manufacturing time is unknown and the biggest factor of course. I will have to buy 50+ evap cores to make this happen, so even if you are a year or more away from buying one speak up. Any feedback and who wants one? |
dadaDaveed |
Oct 6 2014, 09:35 PM
Member Group: Members Posts: 111 Joined: 19-February 09 From: San Antonio, TX Member No.: 10,071 Region Association: Southwest Region |
How's it coming along?
Lo-Fi Version | Time is now: 17th May 2024 - 10:40 PM |
