Paddleshifter?, Transmission linkage |
Dunc |
Jul 24 2014, 09:05 AM
Newbie Group: Members Posts: 37 Joined: 4-July 14 From: Kennewick, WA Member No.: 17,590 Region Association: Pacific Northwest |
Has anyone installed a paddleshift system on the 901 transmission? I would be interested to hear about the experience....i.e. installation difficulties, cost, vendor, etc.
stugray |
Jul 24 2014, 11:44 PM
Advanced Member Group: Members Posts: 3,824 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None |
I actually thought about this some more and came up with this:
Take a tail cone similar to a tail shift. Install a cam through it horizontal & perpendicular to the shift rods. Each shift rod has one rockerarm/follower and one camlobe on the camshaft. Each camlobe has three heights: In, Middle (neutral) and Out. The cam would have 6 positions each one 60 degrees from the last. (neutral is 1/2 way between rev & 1st) If you turn the cam from the first position: rev -> lobe1 = Out, lobe2 = Mid, lobe3 = mid neut -> lobe1 = Mid, lobe2= mid, lobe3= mid 1st -> lobe1 = In, lobe2 = Mid, lobe3 = mid 2nd -> lobe1 = Mid, lobe2 = Out, lobe3 = mid etc etc. Then your shifter is just a cog turning mechanism that can bump the cam one up or one down (CW or CCW) |
CrashDown |
Jul 24 2014, 11:53 PM
Fake Carbon Fiber MASTA! Group: Members Posts: 159 Joined: 8-June 09 From: Union City, CA Member No.: 10,453 Region Association: Northern California |
I actually thought about this some more and came up with this: Take a tail cone similar to a tail shift. Install a cam through it horizontal & perpendicular to the shift rods. Each shift rod has one rockerarm/follower and one camlobe on the camshaft. Each camlobe has three heights: In, Middle (neutral) and Out. The cam would have 6 positions each one 60 degrees from the last. (neutral is 1/2 way between rev & 1st) If you turn the cam from the first position: rev -> lobe1 = Out, lobe2 = Mid, lobe3 = mid neut -> lobe1 = Mid, lobe2= mid, lobe3= mid 1st -> lobe1 = In, lobe2 = Mid, lobe3 = mid 2nd -> lobe1 = Mid, lobe2 = Out, lobe3 = mid etc etc. Then your shifter is just a cog turning mechanism that can bump the cam one up or one down (CW or CCW) This made my head hurt.... |
Lo-Fi Version | Time is now: 19th May 2024 - 04:30 AM |
