Which dizzy for carbs? |
rick 918-S |
Jul 26 2014, 06:46 PM
Hey nice rack! -Celette Group: Members Posts: 20,422 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
2.0 with 40's. Which dizzy works best. I need the F.I. one for another engine so I need a replacement. .09? .050? and why?
bdstone914 |
Jul 26 2014, 07:33 PM
bdstone914 Group: Members Posts: 4,512 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
I was told to use an FI distributor and only hook up the vacuum advance. It's a 1.7 with 40 Kadrons. Just getting it dialed in but seems to work ok. I think I still have some more complete ones if that turns out to be a good choice for you.
rick 918-S |
Jul 26 2014, 10:17 PM
I was told to use an FI distributor and only hook up the vacuum advance. It's a 1.7 with 40 Kadrons. Just getting it dialed in but seems to work ok. I think I still have some more complete ones if that turns out to be a good choice for you. It's my understanding that you don't have ported vacuum with webers so the vacuum advance is NFG. So the key as I understand is to get a dizzy with an optimal mechanical advance. So if I'm correct in my understanding I'm wonder who has experience with mechanical advance dizzies and which one is the best baseline choice. |
brant |
Jul 26 2014, 10:43 PM
914 Wizard Group: Members Posts: 11,613 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
The 050 was the old school stand by choice
Mallory is great The ljet distributors also but one is curved better than the other |
PotterPorsche |
Jul 26 2014, 10:45 PM
Member Group: Members Posts: 295 Joined: 10-November 13 From: Hayward CA Member No.: 16,628 Region Association: None |
009 fine for 2.0 with 44 webers. Better is mallory unilite distributor. Or use a locked out dustributor and buy cb performance black box.You have choices
JFJ914 |
Jul 27 2014, 07:42 AM
Senior Member Group: Benefactors Posts: 813 Joined: 13-June 03 From: Alpharetta, GA Member No.: 814 Region Association: South East States |
It's my understanding that you don't have ported vacuum with webers so the vacuum advance is NFG. So the key as I understand is to get a dizzy with an optimal mechanical advance. So if I'm correct in my understanding I'm wonder who has experience with mechanical advance dizzies and which one is the best baseline choice. Most Weber 40's have a vacuum port, it's next to the aux air adj with a small screw in it. Make a tube and connect it up. |
brant |
Jul 27 2014, 07:51 AM
And the 009 is the wrong advance curve. Notorious for flat spots and poor performance
rick 918-S |
Jul 27 2014, 08:09 AM
It's my understanding that you don't have ported vacuum with webers so the vacuum advance is NFG. So the key as I understand is to get a dizzy with an optimal mechanical advance. So if I'm correct in my understanding I'm wonder who has experience with mechanical advance dizzies and which one is the best baseline choice. Most Weber 40's have a vacuum port, it's next to the aux air adj with a small screw in it. Make a tube and connect it up. Thanks for the info. Is it ported vacuum? If it's direct intake vacuum it will just pull the advance in and hold it. |
michael7810 |
Jul 27 2014, 08:48 AM
Senior Member Group: Members Posts: 1,079 Joined: 6-June 11 From: Scottsdale, AZ Member No.: 13,164 Region Association: Southwest Region |
My 40IDFs have both direct and ported vacuum. The ported is a small tube with a threaded plug and the direct is a plug threaded directly into the base. I'm using the Aircooled.net single vacuum dual advance (SVDA) that was setup for carbs and I'm happy with it. It's the only dizzy I've used so I don't have anything to compare it with.
anderssj |
Jul 27 2014, 10:31 AM
Dog is my copilot... Group: Members Posts: 1,652 Joined: 28-January 03 From: VA Member No.: 207 Region Association: MidAtlantic Region |
been running a recurved 050 on a mod'ed 2L with dell DRLA40s for over 25 years. probably have lost the spec's on the recurve, but will look for them if you're interested.
Steve A- |
JFJ914 |
Jul 27 2014, 10:38 AM
It's my understanding that you don't have ported vacuum with webers so the vacuum advance is NFG. So the key as I understand is to get a dizzy with an optimal mechanical advance. So if I'm correct in my understanding I'm wonder who has experience with mechanical advance dizzies and which one is the best baseline choice. Most Weber 40's have a vacuum port, it's next to the aux air adj with a small screw in it. Make a tube and connect it up. Thanks for the info. Is it ported vacuum? If it's direct intake vacuum it will just pull the advance in and hold it. This is from the web, pretty much says it all. Note the last highlighted part! Vacuum Advance 101 This was written by a former GM engineer as a response to a similar question on a Camaro board: As many of you are aware, timing and vacuum advance is one of my favorite subjects, as I was involved in the development of some of those systems in my GM days and I understand it. Many people don't, as there has been very little written about it anywhere that makes sense, and as a result, a lot of folks are under the misunderstanding that vacuum advance somehow compromises performance. Nothing could be further from the truth. I finally sat down the other day and wrote up a primer on the subject, with the objective of helping more folks to understand vacuum advance and how it works together with initial timing and centrifugal advance to optimize all-around operation and performance. I have this as a Word document if anyone wants it sent to them - I've cut-and-pasted it here; it's long, but hopefully it's also informative. TIMING AND VACUUM ADVANCE 101 The most important concept to understand is that lean mixtures, such as at idle and steady highway cruise, take longer to burn than rich mixtures; idle in particular, as idle mixture is affected by exhaust gas dilution. This requires that lean mixtures have "the fire lit" earlier in the compression cycle (spark timing advanced), allowing more burn time so that peak cylinder pressure is reached just after TDC for peak efficiency and reduced exhaust gas temperature (wasted combustion energy). Rich mixtures, on the other hand, burn faster than lean mixtures, so they need to have "the fire lit" later in the compression cycle (spark timing retarded slightly) so maximum cylinder pressure is still achieved at the same point after TDC as with the lean mixture, for maximum efficiency. The centrifugal advance system in a distributor advances spark timing purely as a function of engine rpm (irrespective of engine load or operating conditions), with the amount of advance and the rate at which it comes in determined by the weights and springs on top of the autocam mechanism. The amount of advance added by the distributor, combined with initial static timing, is "total timing" (i.e., the 34-36 degrees at high rpm that most SBC's like). Vacuum advance has absolutely nothing to do with total timing or performance, as when the throttle is opened, manifold vacuum drops essentially to zero, and the vacuum advance drops out entirely; it has no part in the "total timing" equation. At idle, the engine needs additional spark advance in order to fire that lean, diluted mixture earlier in order to develop maximum cylinder pressure at the proper point, so the vacuum advance can (connected to manifold vacuum, not "ported" vacuum - more on that aberration later) is activated by the high manifold vacuum, and adds about 15 degrees of spark advance, on top of the initial static timing setting (i.e., if your static timing is at 10 degrees, at idle it's actually around 25 degrees with the vacuum advance connected). The same thing occurs at steady-state highway cruise; the mixture is lean, takes longer to burn, the load on the engine is low, the manifold vacuum is high, so the vacuum advance is again deployed, and if you had a timing light set up so you could see the balancer as you were going down the highway, you'd see about 50 degrees advance (10 degrees initial, 20-25 degrees from the centrifugal advance, and 15 degrees from the vacuum advance) at steady-state cruise (it only takes about 40 horsepower to cruise at 50mph). When you accelerate, the mixture is instantly enriched (by the accelerator pump, power valve, etc.), burns faster, doesn't need the additional spark advance, and when the throttle plates open, manifold vacuum drops, and the vacuum advance can returns to zero, retarding the spark timing back to what is provided by the initial static timing plus the centrifugal advance provided by the distributor at that engine rpm; the vacuum advance doesn't come back into play until you back off the gas and manifold vacuum increases again as you return to steady-state cruise, when the mixture again becomes lean. The key difference is that centrifugal advance (in the distributor autocam via weights and springs) is purely rpm-sensitive; nothing changes it except changes in rpm. Vacuum advance, on the other hand, responds to engine load and rapidly-changing operating conditions, providing the correct degree of spark advance at any point in time based on engine load, to deal with both lean and rich mixture conditions. By today's terms, this was a relatively crude mechanical system, but it did a good job of optimizing engine efficiency, throttle response, fuel economy, and idle cooling, with absolutely ZERO effect on wide-open throttle performance, as vacuum advance is inoperative under wide-open throttle conditions. In modern cars with computerized engine controllers, all those sensors and the controller change both mixture and spark timing 50 to 100 times per second, and we don't even HAVE a distributor any more - it's all electronic. Now, to the widely-misunderstood manifold-vs.-ported vacuum aberration. After 30-40 years of controlling vacuum advance with full manifold vacuum, along came emissions requirements, years before catalytic converter technology had been developed, and all manner of crude band-aid systems were developed to try and reduce hydrocarbons and oxides of nitrogen in the exhaust stream. One of these band-aids was "ported spark", which moved the vacuum pickup orifice in the carburetor venturi from below the throttle plate (where it was exposed to full manifold vacuum at idle) to above the throttle plate, where it saw no manifold vacuum at all at idle. This meant the vacuum advance was inoperative at idle (retarding spark timing from its optimum value), and these applications also had VERY low initial static timing (usually 4 degrees or less, and some actually were set at 2 degrees AFTER TDC). This was done in order to increase exhaust gas temperature (due to "lighting the fire late") to improve the effectiveness of the "afterburning" of hydrocarbons by the air injected into the exhaust manifolds by the A.I.R. system; as a result, these engines ran like crap, and an enormous amount of wasted heat energy was transferred through the exhaust port walls into the coolant, causing them to run hot at idle - cylinder pressure fell off, engine temperatures went up, combustion efficiency went down the drain, and fuel economy went down with it. If you look at the centrifugal advance calibrations for these "ported spark, late-timed" engines, you'll see that instead of having 20 degrees of advance, they had up to 34 degrees of advance in the distributor, in order to get back to the 34-36 degrees "total timing" at high rpm wide-open throttle to get some of the performance back. The vacuum advance still worked at steady-state highway cruise (lean mixture = low emissions), but it was inoperative at idle, which caused all manner of problems - "ported vacuum" was strictly an early, pre-converter crude emissions strategy, and nothing more. What about the Harry high-school non-vacuum advance polished billet "whizbang" distributors you see in the Summit and Jeg's catalogs? They're JUNK on a street-driven car, but some people keep buying them because they're "race car" parts, so they must be "good for my car" - they're NOT. "Race cars" run at wide-open throttle, rich mixture, full load, and high rpm all the time, so they don't need a system (vacuum advance) to deal with the full range of driving conditions encountered in street operation. Anyone driving a street-driven car without manifold-connected vacuum advance is sacrificing idle cooling, throttle response, engine efficiency, and fuel economy, probably because they don't understand what vacuum advance is, how it works, and what it's for - there are lots of long-time experienced "mechanics" who don't understand the principles and operation of vacuum advance either, so they're not alone. Vacuum advance calibrations are different between stock engines and modified engines, especially if you have a lot of cam and have relatively low manifold vacuum at idle. Most stock vacuum advance cans aren't fully-deployed until they see about 15" Hg. Manifold vacuum, so those cans don"t work very well on a modified engine; with less than 15" Hg. at a rough idle, the stock can will 'dither' in and out in response to the rapidly-changing manifold vacuum, constantly varying the amount of vacuum advance, which creates an unstable idle. Modified engines with more cam that generate less than 15" Hg. of vacuum at idle need a vacuum advance can that's fully-deployed at least 1", preferably 2" of vacuum less than idle vacuum level so idle advance is solid and stable; the Echlin #VC-1810 advance can (about $10 at NAPA) provides the same amount of advance as the stock can (15 degrees), but is fully-deployed at only 8" of vacuum, so there is no variation in idle timing even with a stout cam. For peak engine performance, driveability, idle cooling and efficiency in a street-driven car, you need vacuum advance, connected to full manifold vacuum. Absolutely. Positively. |
rick 918-S |
been running a recurved 050 on a mod'ed 2L with dell DRLA40s for over 25 years. probably have lost the spec's on the recurve, but will look for them if you're interested. Steve A- Ya, great! always looking for info on what works. (IMG:style_emoticons/default/biggrin.gif) |
Jul 27 2014, 10:48 AM
Mallory is the best one, as far as I know.
--DD |
rick 918-S |
Jul 27 2014, 11:51 AM
Nice write up John. I'm from the old school of ported vacuum connection. Actually, my BBC tri-power ran a ported vacuum style dizzy. That's where I cut my teeth at age 18. It was the first car I built from the ground up and painted. The engine was in a 66 Chevelle. I ran the car on the street and 1/4 mile. A daily driver that ran in the 11's on the weekend. I have zero experience with down draft carbs so the article you posted is enlightening. I'm sure not only for me but others here.
Elliot Cannon |
Jul 27 2014, 12:53 PM
I installed one of these a few years ago. It works great although the cooling tin had to be "massaged" a bit because of the larger diameter of the dist. http://www.pertronix.com/prod/new/details.aspx?ID=110
PotterPorsche |
Jul 27 2014, 04:53 PM
009 works till you save up for mallory. I have the mallory haven't installed yet.
ThePaintedMan |
Jul 27 2014, 04:59 PM
Advanced Member Group: Members Posts: 3,885 Joined: 6-September 11 From: St. Petersburg, FL Member No.: 13,527 Region Association: South East States |
Rick,
Another option if you're trying to save a couple of bucks is the SVDA - sold by Aircooled.net. Again, using a vacuum advance is going to net 1-2 mpg if set up correctly as well. Obviously you know the difference between ported and manifold vacc. But in case anyone else needs a reference, the "later" style Webers came with both - check my carb rebuild thread in my signature. The SVDA is intended to work with ported vaccuum. |
rick 918-S |
Jul 27 2014, 05:39 PM
Rick, Another option if you're trying to save a couple of bucks is the SVDA - sold by Aircooled.net. Again, using a vacuum advance is going to net 1-2 mpg if set up correctly as well. Obviously you know the difference between ported and manifold vacc. But in case anyone else needs a reference, the "later" style Webers came with both - check my carb rebuild thread in my signature. The SVDA is intended to work with ported vaccuum. Thanks George. I'll give it a read. (IMG:style_emoticons/default/smile.gif) |
Lo-Fi Version | Time is now: 26th April 2024 - 12:03 PM |
