Compression question, What should I do? |
monkeyboy |
Jul 27 2014, 01:21 PM
Senior Member Group: Members Posts: 808 Joined: 8-June 08 From: Los Angeles, Ca Member No.: 9,147 Region Association: None |
I pulled my motor out of the car to work on my Fuel Injection project.
When I pulled the motor I did a compression test. Cylinder 3 and 4 are at 115-120 PSI, and 1 and 2 are at 130 PSI. Is that difference anything to worry about? Leakdown is only 2-3 % on any cylinder. Should I yank the heads and check the deck height since I have it apart, or is this not enough to worry about on a stock 2.0? |
monkeyboy |
Jul 27 2014, 01:47 PM
Mark, I took the rocker arms off. I will try it again with no valves opening.
Would 15 PSI be enough to tear off the heads if it is indeed the case? |
Lo-Fi Version | Time is now: 23rd May 2024 - 08:48 PM |
