Compression question, What should I do? |
monkeyboy |
Jul 27 2014, 01:21 PM
Senior Member Group: Members Posts: 808 Joined: 8-June 08 From: Los Angeles, Ca Member No.: 9,147 Region Association: None |
I pulled my motor out of the car to work on my Fuel Injection project.
When I pulled the motor I did a compression test. Cylinder 3 and 4 are at 115-120 PSI, and 1 and 2 are at 130 PSI. Is that difference anything to worry about? Leakdown is only 2-3 % on any cylinder. Should I yank the heads and check the deck height since I have it apart, or is this not enough to worry about on a stock 2.0? |
euro911 |
Jul 27 2014, 03:03 PM
Retired & living the dream. God help me if I wake up! Group: Members Posts: 8,849 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California |
See my edited post (above)
If you're building a new motor, I wouldn't worry about it now. Let's see what you get when you re-test (IMG:style_emoticons/default/popcorn[1].gif) |
Lo-Fi Version | Time is now: 18th May 2024 - 06:49 AM |
