air fan connections |
GreatPumpkin |
Jul 27 2014, 08:19 PM
Member Group: Members Posts: 122 Joined: 28-October 07 From: Centerville OHIO Member No.: 8,272 Region Association: None |
I was wondering why my air fan wouldn't work so when I went to look at the connection behind the ash tray I realized that three wires were not connected at all. im guessing that would be the problem. (IMG:style_emoticons/default/dry.gif) anyway I was wondering if you guys could help me out in telling me which wire goes to which connection. I have a white and yellow wire, a white and green wire and an all white wire. I was wondering if you guys could tell me which is the correct connection for each wire. Thanks!
Attached thumbnail(s) |
walterolin |
Jul 27 2014, 08:45 PM
Senior Member Group: Members Posts: 685 Joined: 30-November 11 From: Louisville, Ky Member No.: 13,838 Region Association: South East States |
Left spade would be white, center would be white/green, and right would be white/yellow. On the other side, not visible in your picture, is a fourth spade which is brown/white in my car. The schematic in Haynes shows this to be a red/white. And there is a short brown ground wire attached to the pivot arm which would be just out of the picture at the bottom. This should be plugged into a nearby ground spade.
I took this info from my notes which I made when I pulled the controls last year. I have a 1970. Wait till someone else chimes in and offers confirmation before you try it out. Olin |
GreatPumpkin |
Jul 27 2014, 09:15 PM
so starting farthest back it the correct sequence would be white, white/green, and then white/yellow. I also have a 1970.
walterolin |
Jul 27 2014, 10:09 PM
Yes, if "farthest back" means the spade with the red and yellow wires in the background.
GreatPumpkin |
Jul 28 2014, 12:08 AM
thank you
Lo-Fi Version | Time is now: 28th March 2024 - 12:59 PM |
