exhaust stubs, thinking of cutting a heat exchanger |
worn |
Jul 28 2014, 01:46 PM
can't remember Group: Members Posts: 3,156 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest |
Can any one out there comment on the idea of cutting off the 6 inches or so of the heat exchanger where it meets the heads and adding flanges there so that the exhaust can be dropped without disturbing the head joint?
I have a spare set of heads so I ws thinking of mounting the heat exchangers, slicing and then tack welding the flanges while still in place. I was thinking of using V flanges with rings as well so you could still get to the head studs with a socket. Ideas? (IMG:style_emoticons/default/popcorn[1].gif) |
Lo-Fi Version | Time is now: 18th May 2024 - 06:45 AM |
