OT:I had to replace the engine in my truck, Here are some SAD pictures.... |
machina |
Jan 23 2005, 11:45 AM
what year is your truck? is it really worth enough to sink over $5 grand in? what about getting the thing running and trading it in for something a little newer with low miles? |
jwalters |
Jan 23 2005, 12:07 PM
Sooo Close....... Group: Members Posts: 1,677 Joined: 14-May 04 From: Huntsville, AL Member No.: 2,068 Region Association: Europe |
(IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) I have personally used valvoline hd 30w exclusively-in the teener, natural dinosaurs only,,and 20-50 in all other vehicles-whenever I take something engine wise apart for what ever reason , it is super clean inside--and my 1.7 motor has perfect rod and main journals, no wear at all, even my cylinders still have some cross hatch in them---do not know what the po used prior to me getting it, but it was obviously very high quality stuff. even the stock lifters were still useable, and my records ( take with a grain of salt ) Shows a rebuild on it somewhere over twenty years ago--it did sit for over 8 yrs in a warehouse tho--that much is confirmed.
All my power junky friends here at work swear by kendall and Amsoil--but they are v-8 watercooled engines, and those oils are tailored for the regime. Start a poll--see what the multitude is using and the results of same!!! This would be beneficial for all concerned on this board.................... (IMG:http://www.914world.com/bbs2/html/emoticons/aktion035.gif) |
Thorshammer |
Jan 23 2005, 12:20 PM
Senior Member Group: Members Posts: 749 Joined: 11-November 03 Member No.: 1,335 |
Obviously the 914 has been getting the attention lately. But, the type of carbon build up you have is from a very high ash content oil. also from not changing it often enough. Being that the oil in that engine has been subjected to very high heat, and lack of maintenance, its a wonder it lasted this long. So enough with beating you up about this. Two things. What do you use the truck for, and what temperature does the motor run at. Because the lifter galley appears in the photos to have many more deposits than the rocker area, which means the deposits are more in the areas that run hotter. So two things, Break it in on non synthetic oil then switch to a synthetic for the reduction in carbon build up/Sludge. And double check what T stat is in the truck and how hot it is running. Do you tow your 914 to races with this truck??? There may be the heat issue. Just my 2 cents. And JC what did you get a F ing crate motor from mopar. I would do that motor for 2K fresh incuding R&R. Hope you got an upgrade.
This problem is not Jiffy Lube or any other "quick lube" place and you know it. Just not maintained as well as it should have been. I use those places all the time, and have excellent results with them. Just make sure you check the oil pressure gauge after you start the thing. It never happened to me, but my friends RX7 got a new motor courtesy of Valvoline Quick lube back in 1994. And for those of you that have bought the "slick 50" scam, better do some research. Start with oil SAE papers and then Continental aircraft engines dated about 1970. Cont did testing on PTFE particulate oils 35 years ago and their findings were this: if the particles were large enough to prevent metal to metal contact, then they would not make it through the oil filter and also clog oil passages. Now some one will obviously say I got 4 MPG more when I started using Slick 50, ever try changing the oil and slick 50 out of the engine and confirming that. Probably not. But I assure you it is the best time enduring scam as far as oils go. Oh, and someone else may say Aircraft filters filter smaller particulate than car filters. Not these days bud. 15 micron is the standard and some even better. Continental stated that unfiltered particulates of better that 25 micron were necessary to prevent metal to metal contact. Also when they tried 25-30 microm PTFE particles a reduction in oil flow was noted after 3 hours of running. Upon disassembly some oil galleys were partially plugged. Not good. So think about this next time you ante up 11.50 at Walmart for some Greased Lightening,Slick 50,Snake500 or whatever the hell they are calling it these days. Erik Madsen Post Script: Check out the snow! Go Patriots Attached image(s) |
jd74914 |
Jan 23 2005, 12:52 PM
I use:
Castrol in the trucks and van Mobil 1 in the porsches I make sure to change the oil often, ATLEAST once every 3000miles I don't care what people say about how oil has improved (IMG:http://www.914world.com/bbs2/html/emoticons/bs.gif) , or how filters are better, every 3000miles. Sorry about the engine. Last engine I screwed was really old and had always used non detergent oil I put detergent oil in it and all hell broke loose. (IMG:http://www.914world.com/bbs2/html/emoticons/headbang.gif) It needed a rebuild anyways (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) |
McMark |
Jan 23 2005, 01:04 PM
What about engine sludge reducers? Seems hard to fine, I shopped my FLAPs and found a lot of "treatments" but only the NAPA brand (Mac) had a cleaner that you weren't supposed to actually drive with it in the car. You put it in, idled for 5 minutes, and then drained it. Seems to me something like that has some strong oil breakdown chemicals which would really eat the sludge.
URY914 |
Jan 24 2005, 08:18 AM
I built the lightest 914 in the history of mankind. Group: Members Posts: 120,725 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
The truck is a '99 and it was just paid off in November. So I'll transfer the Visa balance to a zero intrest account and start making monthly payments on the engine instead of the truck. (IMG:http://www.914world.com/bbs2/html/emoticons/sad.gif) Paul |
URY914 |
Jan 24 2005, 08:30 AM
Erik, Talk about adding insult to injury. You're some smart guy if you can tell me all about my driving, maintance, type of oil I use and be able to do an autopsy of my engine by looking at a few pictures. You need to call the Discovery Channel and see if they can hook you up with your own show. It will be like a cross between Dr.Phil and Dr. Ruth. Thank you for your in put. I feel so much better now. Paul |
Rouser |
Jan 24 2005, 06:44 PM
Anti-Post Whore Group: Benefactors Posts: 597 Joined: 30-December 02 From: Citrus Park, Florida Member No.: 54 |
Crap, Erik ... kind words!
Better yet, get him on "Rides" and wax eloquent about his friend's new RX-7 motor. Sheesh ... |
Joe Bob |
Jan 24 2005, 06:59 PM
Ahem...make ya a deal on a '00 Dakota with a 360 and a blower....four door truck with a shell, cool stereo and LSD....35K miles....oil was changed religously....
Mueller |
Jan 24 2005, 07:01 PM
bummer...sh!t happens it seems.....I came "thisssss" close to launching the motor in the wifes Volvo last week due to lack of maintenance...I thought she had the oil changed about a month ago, it must have been almost a year by how low the oil was (3.5 quarts to start seeing something on the stick)...and to think that earlier in the week and even that day I had rev'd the motor well over 6K a few times hot-rodding around (gotta love boost (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) )
I hear ya on not wanting to get a new truck, mine is paid for as well...if I launch the motor or tranny, I'll drop a new one in and continue to motor on.... |
DuckRyder |
Jan 26 2005, 10:45 AM
Avatars Mode: OFF because of the recalcitrant few. Group: Benefactors Posts: 767 Joined: 8-January 03 From: Georgia Member No.: 110 |
Paul,
Weren't you having problems with that engine when I got the wheels from you? It sucks that it has to be replaced, but if it has not already been replaced you seriously should look at one of the MP 360's. Its hard to know what part of the 5000.00 is the actual engine since there are so many extras that need to be done when the engine is replaced, but it seems like the 300hp 360 would be comparable cost wise? JMHO. |
URY914 |
Jan 26 2005, 11:03 AM
Yea, I had the rod bearing replaced last year. It looked like sand had scored the bearings somehow. They had deep cuts in the surface. PITA |
Toast |
Jan 26 2005, 01:30 PM
Not bad for carrying sway bars. Group: Members Posts: 3,377 Joined: 20-January 04 From: Las Vegas Member No.: 1,580 Region Association: Southwest Region |
(IMG:http://www.914world.com/bbs2/html/emoticons/ohmy.gif)
Holy (IMG:http://www.914world.com/bbs2/html/emoticons/pain30.gif) ! Sorry man, I feel for ya! (IMG:http://www.914world.com/bbs2/html/emoticons/sad.gif) Good luck. I use Castrol in my toyota pickup and love it! Im my 1776 VW, I used Mobil, Penzoil, and Vavoline.....all caused some very bad problems...Valvoline being the worst! |
dlo914 |
Jan 26 2005, 01:43 PM
Whatchu' lookin' at?!?! Group: Members Posts: 3,432 Joined: 6-September 04 From: San Gabriel, CA Member No.: 2,697 |
here's a horror story...cousin (female) had an old maxima..and the car needed a tune-up. long story short the place that did the job forgot to put oil into the engine, and my cousin didnt know and ended up baking the engine to death within 2 days (IMG:http://www.914world.com/bbs2/html/emoticons/mad.gif) |
Toast |
Jan 26 2005, 01:49 PM
Sounds like you're in Califonia. Oh wait, you are! (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/dry.gif) |
sharper |
Jan 26 2005, 03:46 PM
Member Group: Members Posts: 146 Joined: 5-June 03 From: Woodstock, GA Member No.: 789 Region Association: South East States |
I was changing a blown head gasket in my sister's Intrepid a couple of years ago and the inside of that engine looked identical to this one. I soaked and scrubbed parts for days to get it off. I got everything back together, cranked it up and there was a considerable knocking sound. I pulled off the bottom of the case to discover the main bearings were worn including one that was completely missing (even the backing of it). Needless to say that was the end of it, just wish I would have discovered that before doing the head gasket. I always suspected she hadn't got regular oil changes but she wouldn't fess up to it.
ArtechnikA |
Jan 26 2005, 06:04 PM
but you got like, what, 300 years of service, so you really can't complain ... |
Lo-Fi Version | Time is now: 21st May 2024 - 02:32 AM |
