I think my clutch exploded, Edit...actually a rear axle split in half |
era vulgaris |
Jul 29 2014, 04:35 PM
J is for Genius Group: Members Posts: 982 Joined: 10-November 13 From: Raleigh, NC Member No.: 16,629 Region Association: South East States |
So I was running up to the store to drop off some Red Box movies, and pulling away from a stop sign I heard a loud pop....then the car stopped moving. The engine was still running and idling fine, but when I put it into 1st again and tried to pull away, the car didn't move and I could hear a sound like rocks in a rock tumbler. I'm guessing clutch pieces rattling around the bell housing?
I tried just shifting through the gears while stopped and I could find every gear fine, so I'm hoping it's nothing internal to the trans. Luckily this happened just a few hundred yards from my house in my neighborhood so getting it back to my house was easy. I'm going to have it towed to a local aircooled shop. But does this sound like a clutch disc that shattered, or possibly something more serious? Of course this had to happen just after I sold my Karmann Ghia, so I have no other means of transport except to borrow my girlfriend's car! |
era vulgaris |
Aug 7 2014, 07:32 PM
So is there any way to get a new axle assembly in without removing the heat exchangers?
If not, is there any special knowledge I should be aware of before attempting to remove the heat exchangers? |
76-914 |
Aug 7 2014, 08:02 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,502 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
So is there any way to get a new axle assembly in without removing the heat exchangers? If not, is there any special knowledge I should be aware of before attempting to remove the heat exchangers? I'd start soaking those studs/nuts in PB Blaster a few days prior to removing them. They want to back out of the aluminum leaving you with galled threads. Have a helicoil or timecert kit on hand before you start. Yes they are easy to drill out with the engine in the car if you step drill it. Not a step bit. Use regular bits but three different sizes. The hole acts like a guide when removing minimum amounts of material. |
Lo-Fi Version | Time is now: 18th May 2024 - 05:07 PM |
