I think my clutch exploded, Edit...actually a rear axle split in half |
era vulgaris |
Jul 29 2014, 04:35 PM
J is for Genius Group: Members Posts: 982 Joined: 10-November 13 From: Raleigh, NC Member No.: 16,629 Region Association: South East States |
So I was running up to the store to drop off some Red Box movies, and pulling away from a stop sign I heard a loud pop....then the car stopped moving. The engine was still running and idling fine, but when I put it into 1st again and tried to pull away, the car didn't move and I could hear a sound like rocks in a rock tumbler. I'm guessing clutch pieces rattling around the bell housing?
I tried just shifting through the gears while stopped and I could find every gear fine, so I'm hoping it's nothing internal to the trans. Luckily this happened just a few hundred yards from my house in my neighborhood so getting it back to my house was easy. I'm going to have it towed to a local aircooled shop. But does this sound like a clutch disc that shattered, or possibly something more serious? Of course this had to happen just after I sold my Karmann Ghia, so I have no other means of transport except to borrow my girlfriend's car! |
era vulgaris |
Aug 7 2014, 07:32 PM
So is there any way to get a new axle assembly in without removing the heat exchangers?
If not, is there any special knowledge I should be aware of before attempting to remove the heat exchangers? |
76-914 |
Aug 7 2014, 08:02 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,505 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
So is there any way to get a new axle assembly in without removing the heat exchangers? If not, is there any special knowledge I should be aware of before attempting to remove the heat exchangers? I'd start soaking those studs/nuts in PB Blaster a few days prior to removing them. They want to back out of the aluminum leaving you with galled threads. Have a helicoil or timecert kit on hand before you start. Yes they are easy to drill out with the engine in the car if you step drill it. Not a step bit. Use regular bits but three different sizes. The hole acts like a guide when removing minimum amounts of material. |
era vulgaris |
Aug 7 2014, 08:28 PM
I'd start soaking those studs/nuts in PB Blaster a few days prior to removing them. They want to back out of the aluminum leaving you with galled threads. Have a helicoil or timecert kit on hand before you start. Yes they are easy to drill out with the engine in the car if you step drill it. Not a step bit. Use regular bits but three different sizes. The hole acts like a guide when removing minimum amounts of material. Ugh, this sounds like a nightmare! The problem is that the car is on the ground with the stub axle removed, so I'm afraid to raise it or do anything that would cause the wheel to roll. It's so dumb. With the broken axle halves coming right out, it didn't even occur to me that the exhaust would be in the way. |
Lo-Fi Version | Time is now: 24th May 2024 - 11:00 PM |
