I think my clutch exploded, Edit...actually a rear axle split in half |
era vulgaris |
Jul 29 2014, 04:35 PM
J is for Genius Group: Members Posts: 982 Joined: 10-November 13 From: Raleigh, NC Member No.: 16,629 Region Association: South East States |
So I was running up to the store to drop off some Red Box movies, and pulling away from a stop sign I heard a loud pop....then the car stopped moving. The engine was still running and idling fine, but when I put it into 1st again and tried to pull away, the car didn't move and I could hear a sound like rocks in a rock tumbler. I'm guessing clutch pieces rattling around the bell housing?
I tried just shifting through the gears while stopped and I could find every gear fine, so I'm hoping it's nothing internal to the trans. Luckily this happened just a few hundred yards from my house in my neighborhood so getting it back to my house was easy. I'm going to have it towed to a local aircooled shop. But does this sound like a clutch disc that shattered, or possibly something more serious? Of course this had to happen just after I sold my Karmann Ghia, so I have no other means of transport except to borrow my girlfriend's car! |
ChrisFoley |
Aug 8 2014, 12:39 AM
I am Tangerine Racing Group: Members Posts: 7,933 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
Raise the back end of the car.
With the car jacked up you should be able to get the new axle in without removing the heat exchanger. Jacking up the car lowers the trailing arm relative to the transmission, making it easier to start the stub axle into the hub. |
era vulgaris |
Aug 8 2014, 07:01 AM
Raise the back end of the car. With the car jacked up you should be able to get the new axle in without removing the heat exchanger. Jacking up the car lowers the trailing arm relative to the transmission, making it easier to start the stub axle into the hub. This won't damage the bearing if the wheel turns a little bit? |
Lo-Fi Version | Time is now: 25th May 2024 - 07:24 PM |
