anyone played with boxster gauge cluster? |
skeates |
Jul 29 2014, 09:57 PM
Member Group: Members Posts: 218 Joined: 28-February 05 From: Sacramento, ca Member No.: 3,684 Region Association: Northern California |
Hey guys - I'm not sure if this is a subject that has been beaten to death before (I certainly wasn't able to find any threads on it), but has anyone here ever attempted to make use of the boxster or cousin 996 gauge clusters in a conversion? I was able to find a pin-out diagram for the boxster cluster which makes it look doable. Just curious if there was any fancy shmancy communications between the cluster and the ECU that would need to be worked around?
Mike Bellis |
Jul 30 2014, 07:45 AM
Resident Electrician Group: Members Posts: 8,345 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None |
I'm running a 2000 VW cluster and it does communicate with the ECU via can bus.
I guess the Boxster can be hacked. Chip Foose did it on a Lotus build. Please post the pin out for reference. |
Lo-Fi Version | Time is now: 17th May 2024 - 04:46 AM |
