anyone played with boxster gauge cluster? |
skeates |
Jul 29 2014, 09:57 PM
Member Group: Members Posts: 218 Joined: 28-February 05 From: Sacramento, ca Member No.: 3,684 Region Association: Northern California |
Hey guys - I'm not sure if this is a subject that has been beaten to death before (I certainly wasn't able to find any threads on it), but has anyone here ever attempted to make use of the boxster or cousin 996 gauge clusters in a conversion? I was able to find a pin-out diagram for the boxster cluster which makes it look doable. Just curious if there was any fancy shmancy communications between the cluster and the ECU that would need to be worked around?
Dr Evil |
Sep 17 2014, 09:22 AM
Send me your transmission! Group: Members Posts: 22,995 Joined: 21-November 03 From: Loveland, OH 45140 Member No.: 1,372 Region Association: MidAtlantic Region |
Question, just say you have to rely on the engines EFI and other things talking to each other to get the final 1/4 tank, and those parts are not used on the conversion, would it be feasible to put gauge guts from a different gauge into the pod? As in, use the needle and face of the Boxter pod, but drive the needle with a gauge with a known range and value set.
Lo-Fi Version | Time is now: 17th May 2024 - 01:57 AM |
