anyone played with boxster gauge cluster? |
skeates |
Jul 29 2014, 09:57 PM
Member Group: Members Posts: 218 Joined: 28-February 05 From: Sacramento, ca Member No.: 3,684 Region Association: Northern California |
Hey guys - I'm not sure if this is a subject that has been beaten to death before (I certainly wasn't able to find any threads on it), but has anyone here ever attempted to make use of the boxster or cousin 996 gauge clusters in a conversion? I was able to find a pin-out diagram for the boxster cluster which makes it look doable. Just curious if there was any fancy shmancy communications between the cluster and the ECU that would need to be worked around?
skeates |
Sep 19 2014, 11:28 PM
Just finished taking some voltage readings on the terminals. Looks like they each oscillate between negative 5 volts and positive 5 volts, but at a very slow rate (probably takes about a full minute to go through a cycle. Seems like I might need an oscilloscope to figure out what this signal is looking like.
Lo-Fi Version | Time is now: 19th May 2024 - 01:29 AM |
