anyone played with boxster gauge cluster? |
skeates |
Jul 29 2014, 09:57 PM
Member Group: Members Posts: 218 Joined: 28-February 05 From: Sacramento, ca Member No.: 3,684 Region Association: Northern California |
Hey guys - I'm not sure if this is a subject that has been beaten to death before (I certainly wasn't able to find any threads on it), but has anyone here ever attempted to make use of the boxster or cousin 996 gauge clusters in a conversion? I was able to find a pin-out diagram for the boxster cluster which makes it look doable. Just curious if there was any fancy shmancy communications between the cluster and the ECU that would need to be worked around?
timothy_nd28 |
Sep 19 2014, 11:35 PM
Is the needle fixed at full level but the voltages are still changing from -5 to +5 volts?
The voltages should be stable when the needle stops moving. |
Lo-Fi Version | Time is now: 17th May 2024 - 04:49 AM |
