anyone played with boxster gauge cluster? |
skeates |
Jul 29 2014, 09:57 PM
Member Group: Members Posts: 218 Joined: 28-February 05 From: Sacramento, ca Member No.: 3,684 Region Association: Northern California |
Hey guys - I'm not sure if this is a subject that has been beaten to death before (I certainly wasn't able to find any threads on it), but has anyone here ever attempted to make use of the boxster or cousin 996 gauge clusters in a conversion? I was able to find a pin-out diagram for the boxster cluster which makes it look doable. Just curious if there was any fancy shmancy communications between the cluster and the ECU that would need to be worked around?
904svo |
Sep 19 2014, 08:14 PM
904SVO Group: Members Posts: 1,118 Joined: 17-November 05 From: Woodstock,Georgia Member No.: 5,146 |
From the reading you have a stepper motor gas gauge, you could try to set your
pot to give a full reading on one set of the windings and another pot with reversed battery and ground to give a empty reading ( gas gauge sender ). |
skeates |
Sep 21 2014, 04:09 PM
From the reading you have a stepper motor gas gauge, you could try to set your pot to give a full reading on one set of the windings and another pot with reversed battery and ground to give a empty reading ( gas gauge sender ). Yup! Was banging my head quite a bit yesterday trying to interpret my measurements when I finally decided to challenge the assumption that this was indeed an air-core motor. Switched up the code and tried driving it like a stepper motor....and....success! This explains the transient voltage measurements I was getting while the gauge was moving. I need to play with the code a bit to see if I can get it to step in 1/2 increments since right now it's a pretty rough movement, but here's a video of it sweeping from empty to full: https://www.youtube.com/watch?v=V8I68EIvCgI |
Lo-Fi Version | Time is now: 19th May 2024 - 01:28 AM |
