FS / FT - 914 V8 |
FS / FT - 914 V8 |
Vegas914-V8 |
Jul 31 2014, 02:01 PM
Newbie Group: Members Posts: 8 Joined: 31-July 14 From: Las Vegas Member No.: 17,713 Region Association: None |
SO, I have a 914 V8 conversion project I've been working on for some time now. Started with no kids and no bills.... now I have two kids and just got divorced ha-ha so the car has been on hold for around a year, should be knocking it out soon.
any tips, comments, advice, hate messages, somebody that wants to buy it when im done? I literally have no reason to keep this as it wont hold me and my two sons, leaving this as a "alone time" ride. Plan is to finish the build, and then find a buyer or trade for a crewcab chevy truck (Hopefully). I'll put up more photos when I get around to taking some..... car is mostly sanded to metal at the moment... the random paint colors are from me spraying it to keep the metal that I exposed when I flared the fenders from rusting while it sat. Complete so far...... (IMG:style_emoticons/default/sheeplove.gif) (IMG:style_emoticons/default/piratenanner.gif) (IMG:style_emoticons/default/WTF.gif) BRAKE SYSTEM BMW 320i Front brake calipers Street tech brake pads New rubber brake lines @ calipers New hard brake lines @ Calipers Rear Brake Tee installed, proportioning valve delete New 911 19mm Master Cylinder Rebuilt, Painted Pedal Cluster Bronze pedal Bushings Ceramic Painted Brake Calipers SUSPENSION & TRANSMISSION New fuel line New Wheel Bearings New Shifter Bushings Front to back Rebuilt CV's - Sanded & Painted Axles 9" Flywheel Kennedy Engineering Stage III Clutch & Pressure Plate Kennedy Engineering Throwout Bearing Kennedy Engineering Pilot Bearing IMI-101 High Torque Starter New Tie Rod Ends Weltmeister 180lb Rear Springs Rebuilt / Painted Rear Shocks Custom Wheel Adapters 4x130 to 5x114.5 19" x 8" Wheels 225/35/zr19 Tires ENGINE Rebuilt Chevy Small Block 350 from 1985 Corvette Mild Lunati Cam New Lifters New Pushrods New Rings New Oil Pump New Timing Chain & Gears All Fel-Pro Gaskets Cleaned & Painted Block HEI Distributor New Plugs & Wires Edelbrock RPM Air Gap Intake Holley 650cfm Carb Flowtech Shorty Headers - Ceramic Painted Renegade Hybrids Adapter Plate Renegade Hybrids Water Pump Renegade Hybrids Alternator Bracket Renegade Hybrids Engine Mount Bar Renegade Hybrids HD Chassis Engine Mount Plates Renegade Hybrids Transmission Setback Blocks Renegade Hybrids Harmonic Balancer INTERIOR & BODY Custom Accented Gauge Cluster Alpine Stereo Cleaned & painted Gas Tank Hand Flared Fenders Wheelwells, Undercarriage, Engine Bay, Front Trunk & Suspension components completely coated in rubberized undercoating Truck bed coating in rear trunk $15k COMPLETE $8k AS IS, (I will get radiator setup installed and complete the body work, to Primer. Or Best Offer. Just Make one, I promise I wont cry. Or shoot me an offer. I like trades and need a Crewcab Truck. Attached thumbnail(s) |
Vegas914-V8 |
Feb 19 2015, 10:04 AM
Pacific Islander |
Feb 19 2015, 11:53 AM
I'm new here ... Group: Members Posts: 0 Joined: 11-February 15 From: san diego Member No.: 18,416 Region Association: None |
Lo-Fi Version | Time is now: 15th May 2024 - 09:18 AM |
