It runs !!!!! mickey mouse engineering prevails :), Mallory Dizzy AND D-Jet working together |
Mueller |
Jan 22 2005, 08:55 PM
Background:
For the stock D-Jet, the ECU gets the signal to fire the injectors from a set of mechanical breaker points inside the base of the distributor. There is nothing wrong with the factory method except for the fact that if you want to run the D-Jet injection, you have to keep the factory distributor...not anymore (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) I have successfully been able to electronicly trigger the ECU from a pair of optical sensors inside of the billet Mallory distributor....so far I have only put a few miles onto the car with this setup and I don't know how it'll work when the temperature is much higher (currently it is 45° outside.....) it's ugly right now, but give me some time to clean it up... (IMG:http://www.914world.com/bbs2/html/emoticons/smash.gif) (IMG:http://www.914world.com/bbs2/uploads/post-2-1106100569.jpg) So for my ignition, I have the Mallory distributor, accel coil and new 8.5mm plug wires....starts right up and idles fine, but I might install a CDI box anyways... |
KenH |
Jan 24 2005, 08:10 PM
Senior Member Group: Members Posts: 680 Joined: 16-January 03 From: Gilroy, CA Member No.: 156 |
GARY,
Call Paul - you can buy replacment gears with the "coarse spline" that will convert a 915 LSD. He cloned a ZF and has all the internals - disks & spacers. http://www.guardtransmission.com/lsd_info.htm Ken |
Lo-Fi Version | Time is now: 18th May 2024 - 03:00 PM |
