Speedometer cable connection to speedo, Disconnection Q.... |
jim_hoyland |
Aug 2 2014, 03:38 PM
Get that VIN ? Group: Members Posts: 9,298 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California |
Can the speedo cable connection be undone from the speedo WITHOUT removing the cluster ? I don't have small hands.
I want to test a speedo for a short drive.... (IMG:style_emoticons/default/smile.gif) |
Eric_Shea |
Aug 2 2014, 04:15 PM
Sure. Assume the position. The 914 wiring position.
Lay under the dash and reach up. I've done it a number of times. |
monkeyboy |
Aug 4 2014, 09:37 AM
Senior Member Group: Members Posts: 808 Joined: 8-June 08 From: Los Angeles, Ca Member No.: 9,147 Region Association: None |
Or grab the gauge by the bezel and pull it out. If the gasket is old enough, you can slip them out enough to unscrew the speedo cable.
Mblizzard |
Aug 4 2014, 10:37 AM
Or grab the gauge by the bezel and pull it out. If the gasket is old enough, you can slip them out enough to unscrew the speedo cable. (IMG:style_emoticons/default/agree.gif) If you can't get the speedo out first, try the tach. Then you will have more room to push out the speedo. Having Man Hands can be a problem on these cars! |
Lo-Fi Version | Time is now: 16th May 2024 - 09:38 PM |
