Replaceing the pos Optima red top . batt, failed after 4 years . now going cheap sob route . Whats works best |
thelogo |
Aug 3 2014, 04:47 PM
Senior Member Group: Retired Members Posts: 1,510 Joined: 6-April 10 Member No.: 11,572 Region Association: None |
Optima was solid for the most part but now I want something
Cheaper . The car sometimes sits in garage for 3 weeks at a time . I have the trickle charger . But I want to avoid a high dollar batt because I just accept the fact that these cars That sit a lot Need more frequent batt replacement then something New/ modern / not boxer . That's driven daily . So what is recommended ? (IMG:style_emoticons/default/sawzall-smiley.gif) My father never drank ,smoked gambled or chased women and I wasn't going to either "Ty Cobb " |
mgp4591 |
Aug 3 2014, 04:50 PM
914 Guru Group: Members Posts: 5,374 Joined: 1-August 12 From: Salt Lake City Ut Member No.: 14,748 Region Association: Intermountain Region |
I'd go for another Optima Red Top. Mine's been running (altho in my dd for over 10 years, rated @ 750 cca but never tests less than 920cca. Put a negative quick disconnect on anything you don't drive alot- seconds to turn off and saves batteries!
thelogo |
Aug 3 2014, 05:03 PM
I did recently get the quick disconnect on the negitive post aka( big red key )
But the battery had already deteriorated past the point of no return . |
tradisrad |
Aug 3 2014, 05:57 PM
I've not had luck with optima batteries. My first started draining even when it was not hooked up. My current Optima goes dead in a few weeks if I leave it hooked up. on the flip side my friend's optima has been good for year and years.
bandjoey |
Aug 3 2014, 09:28 PM
bandjoey Group: Members Posts: 4,926 Joined: 26-September 07 From: Bedford Tx Member No.: 8,156 Region Association: Southwest Region |
$89 at Walmart. 3 years and no failure. Texas heat. Daily driver. I'm happy.
c12croft |
Aug 3 2014, 09:49 PM
Member Group: Members Posts: 167 Joined: 24-December 04 From: Long Island, New York Member No.: 3,331 |
I'm told these optima batts need and optima charge using trickle setting.
Problem is that these chargers are north of $150. Expensive to show off those red tops. |
thelogo |
Aug 3 2014, 10:16 PM
Sounds good to me ,but my Walmart has zero customer support in the automotive dept So I would need to know exactly what battery I need . |
Java2570 |
Aug 4 2014, 06:54 AM
Senior Member Group: Members Posts: 649 Joined: 7-May 11 From: Fishers, IN Member No.: 13,035 Region Association: Upper MidWest |
I replaced my old battery with an Interstate battery. I was going to look at Optima but my brother (works at an auto shop) says that Optima has gone through a lot of poor quality issues in the last 5+ years. I've heard they have gotten a little better of late but I don't believe the Optima is much better than a regular battery anymore. I'll go for a pricey dry cell battery next time.
daraho9146 |
Aug 4 2014, 09:09 AM
Newbie Group: Members Posts: 20 Joined: 3-July 14 From: Corrales, NM Member No.: 17,582 Region Association: None |
I replaced my old battery with an Interstate battery. I was going to look at Optima but my brother (works at an auto shop) says that Optima has gone through a lot of poor quality issues in the last 5+ years. I've heard they have gotten a little better of late but I don't believe the Optima is much better than a regular battery anymore. I'll go for a pricey dry cell battery next time. The main advantage of the Optima battery: No battery acid. I had the Exide version of the Optima in my 914-6 for 10 years. It went dead. I instinctively replaced it with the Optima. It went dead. I opened the shroud to replace the alternator. I found out that the mechanic that replaced the alternator in the 3.2 did not seat the connections properly. Who knows? I might still be using the original Exide battery if not for the alternator glitch. |
thelogo |
Aug 4 2014, 03:40 PM
I found a guy selling all remanufactured
Batteries 50 bucks with 1 month guarante But the batteries have no labels or specs On them , as in amps ,group nothing. |
Valy |
Aug 4 2014, 05:10 PM
Senior Member Group: Members Posts: 1,675 Joined: 6-April 10 From: Sunnyvale, CA Member No.: 11,573 Region Association: Northern California |
Costco battery (re-branded Interstate).
Longest warranty, low price. Batteries have a lifespan of about 4 years. Anything more than that is just luck. This has nothing to do with the manufacturer, it's just physics and chemistry as there's a limit to the amount of times you can decompose and recompose the lead plates before they brake down or the residue shorts them at the bottom. I believe the key here is the warranty period you get. Any battery will fail so it's better if you're cover for the longest period of time. |
Mark Henry |
Aug 4 2014, 05:22 PM
The optima in my bug is 12 years old, the one thing I've always done is run it...once the summer is over it goes into my winter car.
I was thinking this next... http://www.odysseybatteries.com/applications/auto.htm |
TheCabinetmaker |
Aug 4 2014, 05:43 PM
I bought two optimas 12 years ago. One died in about 5 years. The other still powers my daily driver.
thelogo |
Aug 6 2014, 08:40 AM
http://m.harborfreight.com/15-Watt-Solar-B...rger-68692.html
Anybody have one of these , is it a joke or could it actually keep the battery In good condition . Price is right . (IMG:style_emoticons/default/driving.gif) |
Lo-Fi Version | Time is now: 16th May 2024 - 11:01 PM |
