Fuch I had a fire! Now repaired, Back together & running. Picking it up next week |
JRust |
Aug 5 2014, 10:10 PM
914 Guru Group: Members Posts: 6,307 Joined: 10-January 03 From: Corvallis Oregon Member No.: 129 Region Association: Pacific Northwest |
I opened my garage tonight to troubleshoot wiring. There was a smokey smell in it pretty strong. No smoke though so I was a little confused. I look in my rear trunk which was open as I was testing ECU wiring the previous night. I did pull one of the 3 relays last night that sit by my ECU. Just wanted to grab some in town to swap out & rule those out as a possible problem. I did not leave the key on or anything. I didn't think to pull the ground. I don't see why I'd need to as all I did was pull a relay. HOW the fuch does this happen just sitting?
I admit I am no genius with wiring but really? How could pulling a relay catch my car on fire? I guess I should feel lucky as this happened in my closed garage with nobody the wiser. It is also just the battery & into my trunk. I sure as hell don't feel lucky. I feel like I got kicked in the nuts repeatedly really hard (IMG:style_emoticons/default/sad.gif) Attached image(s) |
BIGKAT_83 |
Aug 6 2014, 07:25 AM
Senior Member Group: Members Posts: 1,798 Joined: 25-January 03 From: Way down south Bogart,GA Member No.: 194 Region Association: South East States |
Damn.... (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif) Thats going to be alot of work to repair. You are very lucky you didn't burn up the whole car. Does not look like it damaged the ecu($1100). Think I'd just get a new harness from outfront.
In your trouble shooting thread I warned you to be careful. Didn't think it would be like this. |
Lo-Fi Version | Time is now: 27th May 2024 - 02:45 AM |
