Fuch I had a fire! Now repaired, Back together & running. Picking it up next week |
Tom |
Aug 6 2014, 12:13 PM
Advanced Member Group: Members Posts: 2,139 Joined: 21-August 05 From: Port Orchard, WA 98367 Member No.: 4,626 Region Association: None |
Jamie,
Here is some advice. If it happened once, it can happen again. Something was wrong and may have been that way for a while. Take the car to Mike and let him straighten it out. Afterward you will have a schematic of where the wires go and he will make sure to put fuses where they should be. Without a schematic, you can not say pulling a relay could have or could not have caused this. Depends on where and what type of relay it was and exactly what it functioned to do. At least after Mike finishes, he will have some kind of schematic that will tell you what all of the relays do and then later if something does not work, you can use the schematic to troubleshoot the problem. Tom |
Spoke |
Aug 6 2014, 12:31 PM
Jerry Group: Members Posts: 6,972 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
Wow, that sucks.
Good thing it didn't catch other stuff on fire and burn the entire 914 and garage. Looking at the damage, one has to wonder if the battery was shorted, burned, and burned the electronics, or the electronics burned and cause the battery to burn. It would seem that a heavy current drain from the electronics would not cause the battery to burn. The battery should be able to drain 10, 20A without burning up. |
rhodyguy |
Aug 6 2014, 01:12 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,060 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
things really go south right after the connection point under the plastic cover next to the ex-battery. the big reds from that point back to the bat have cooked a bit but after that it's crispy critters. i think things could have wired in a more 'proper' fashion, like the amp and other sections with materials other than household wire nuts and electrical tape to secure things. i'm not meaning to bag on you.
k |
SLITS |
Aug 6 2014, 01:56 PM
China Syndrome.
Mark Henry |
Aug 6 2014, 02:36 PM
Wow!
I don't know if you are unlucky... or horse shoes up the arse lucky for not burning down the house. |
billh1963 |
Aug 6 2014, 03:02 PM
Car Hoarder! Group: Members Posts: 3,402 Joined: 28-March 11 From: South Carolina Member No.: 12,871 Region Association: South East States |
I'm paranoid about fires. All 12 of my "toy" cars have battery disconnect switches or terminals. It not only keeps the battery from draining between drives but minimizes chances of what you just experienced!
JRust |
Aug 6 2014, 07:32 PM
914 Guru Group: Members Posts: 6,305 Joined: 10-January 03 From: Corvallis Oregon Member No.: 129 Region Association: Pacific Northwest |
I do have full coverage with Hagerty. While putting in a claim will make my premium go up. I'm thinking this is going to end up costing a couple grand when it's all said & done. Anyone see any problem with the insurance possibly denying the claim? I'm not exactly sure if this was my fault or what?
billh1963 |
Aug 6 2014, 07:36 PM
I do have full coverage with Hagerty. While putting in a claim will make my premium go up. I'm thinking this is going to end up costing a couple grand when it's all said & done. Anyone see any problem with the insurance possibly denying the claim? I'm not exactly sure if this was my fault or what? It will be interesting to see what Hagerty says. If it's under $2 k or so I would pay out of pocket...that's just me. I wouldn't want an insurance claim for such a small amount. I would rather save the hassle and resultant premium increases and such for something major! |
JRust |
Aug 6 2014, 07:45 PM
It will be interesting to see what Hagerty says. If it's under $2 k or so I would pay out of pocket...that's just me. I wouldn't want an insurance claim for such a small amount. I would rather save the hassle and resultant premium increases and such for something major! Thing is if I have a shop do anything it will easily run over that. I have paint that will need done in both the trunk & engine bay. The wiring may need to be redone completely. Not sure if this has gotten into the loom in the tunnel. It will certainly have to come out to be sure. Odds are good there will be some things on my motor that will need replaced. Yes I can do all that work cheaper. I'll just have to sell some shit to pay for it. Which I can do. Just weighing the pro's & cons of making a claim or not (IMG:style_emoticons/default/idea.gif) |
billh1963 |
Aug 6 2014, 08:14 PM
It will be interesting to see what Hagerty says. If it's under $2 k or so I would pay out of pocket...that's just me. I wouldn't want an insurance claim for such a small amount. I would rather save the hassle and resultant premium increases and such for something major! Thing is if I have a shop do anything it will easily run over that. I have paint that will need done in both the trunk & engine bay. The wiring may need to be redone completely. Not sure if this has gotten into the loom in the tunnel. It will certainly have to come out to be sure. Odds are good there will be some things on my motor that will need replaced. Yes I can do all that work cheaper. I'll just have to sell some shit to pay for it. Which I can do. Just weighing the pro's & cons of making a claim or not (IMG:style_emoticons/default/idea.gif) I understand what you are saying. Does the policy include electrical fires? Accident and collision are obviously covered. Even fires related to fuel issues are covered. I'm just wondering if this would be considered to be in the same category as a mechanical failure? We need an insurance person to chime in.... |
rhodyguy |
Aug 6 2014, 08:40 PM
how much will your premium increase per month if you file a claim?
JRust |
Aug 6 2014, 08:47 PM
KELTY360 |
Aug 6 2014, 10:35 PM
914 Neferati Group: Members Posts: 5,030 Joined: 31-December 05 From: Pt. Townsend, WA Member No.: 5,344 Region Association: Pacific Northwest |
It's been a long time, but I had a claim with Hagerty for a small incident and they were great. They followed up frequently to make sure I was getting proper repairs and my premium didn't increase either. Unlike typical insurance companies, I've always felt they were part of the 'team'. I wouldn't hesitate to call them for advice on the situation. JMO
JRust |
Aug 6 2014, 10:57 PM
It's been a long time, but I had a claim with Hagerty for a small incident and they were great. They followed up frequently to make sure I was getting proper repairs and my premium didn't increase either. Unlike typical insurance companies, I've always felt they were part of the 'team'. I wouldn't hesitate to call them for advice on the situation. JMO Yeah I think I will call them tomorrow. My coverage is great & I have zero deductible. So I may as well see what they have to say. I won't be any worse off finding out. I was going to start tearing stuff out tonight but figured I better not touch anything yet. Really looks to have started with my main power wire running from the starter to the battery. Seeing the damage that makes more sense than the smaller wires up top by the relay. Which coincidentally sit right above the wire running to my starter. Who the hell knows though with this stuff. It sucks & I'm depressed about my car. At the same time I feel blessed it was not worse. I've never seen a battery melted that way. Knowing all the heat was right above my fuel pump & lines. I am counting my blessings my car didn't explode & take the garage with it |
rick 918-S |
Aug 7 2014, 12:41 AM
Hey nice rack! -Celette Group: Members Posts: 20,417 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
Wish I. Could offer some advise but I. Got nothing.
wndsrfr |
Aug 7 2014, 06:02 AM
Senior Member Group: Members Posts: 1,428 Joined: 30-April 09 From: Rescue, Virginia Member No.: 10,318 Region Association: MidAtlantic Region |
Internal short in the battery? What brand is .....was....it? |
arkitect |
Aug 7 2014, 06:34 AM
Senior Member Group: Members Posts: 617 Joined: 3-March 10 From: Stockton, CA Member No.: 11,426 Region Association: None |
Jaime,
I'm sorry that this happened to you. Hope you figure it out and get back on the road without to much expense. Be interesting to see what Hagerty says. Dave (IMG:style_emoticons/default/sad.gif) |
76-914 |
Aug 7 2014, 08:07 AM
Internal short in the battery? What brand is .....was....it? I was wondering the same thing. (IMG:style_emoticons/default/confused24.gif) I'm not an electrical guru but wouldn't a short on anything small, i.e 8ga and smaller, burn through the wire before melting the battery???? I made the starter cover much larger after I noticed how close the Suby starter wire was to the trunk. |
JRust |
Aug 7 2014, 10:52 AM
Called Hagerty to submit a claim. We will see where it goes from there once the adjustor comes out. I'll update here after they come. The adjustor is supposed to call me within 24 hours. Then setup a time to come take a look. I imagine it will be next week before that happens.
KELTY360 |
Aug 7 2014, 11:04 AM
Called Hagerty to submit a claim. We will see where it goes from there once the adjustor comes out. I'll update here after they come. The adjustor is supposed to call me within 24 hours. Then setup a time to come take a look. I imagine it will be next week before that happens. (IMG:style_emoticons/default/popcorn[1].gif) |
Lo-Fi Version | Time is now: 23rd April 2024 - 07:01 PM |
