Is door gap widening when car is lifted normal? |
doug_b_928 |
Aug 10 2014, 08:10 PM
Senior Member Group: Members Posts: 692 Joined: 17-January 13 From: Winnipeg Member No.: 15,382 Region Association: Canada |
I lifted my car for the first time today. The longs have rust and the gap at the top of the door widened (the weight of the rear of the car was pulling it down such that the door gap opened more at the top (see pic below).
I'd say it was double what it is when the wheels are on the ground. So, I won't be surprised if this is because of the rust having weakened the chassis (in fact, I'm glad that it didn't snap off completely), but I'm wondering if some widening like this is normal when the car is lifted from the jack point areas (i.e., using a two post lift) and, if so, how much one should expect. |
Chris H. |
Aug 11 2014, 06:13 PM
Senior Member Group: Members Posts: 4,030 Joined: 2-January 03 From: Chicago 'burbs Member No.: 73 Region Association: Upper MidWest |
That's understandable. The good news is that most of the panels are available that you will probably need. Get it all apart and post some pics. Most likely your longs are very rusty. You'll want to check the suspension ears while you're at it.
Depending on your budget you might want to have someone else get it back to structurally solid and do the rest yourself. Rick 918-S lives in Duluth. He has a Celette bench and his work very well-known. You have to get it lined up just right when you replace the longs or the doors will never line up right. |
Lo-Fi Version | Time is now: 13th May 2024 - 12:22 PM |
