Is door gap widening when car is lifted normal? |
doug_b_928 |
Aug 10 2014, 08:10 PM
Senior Member Group: Members Posts: 692 Joined: 17-January 13 From: Winnipeg Member No.: 15,382 Region Association: Canada |
I lifted my car for the first time today. The longs have rust and the gap at the top of the door widened (the weight of the rear of the car was pulling it down such that the door gap opened more at the top (see pic below).
I'd say it was double what it is when the wheels are on the ground. So, I won't be surprised if this is because of the rust having weakened the chassis (in fact, I'm glad that it didn't snap off completely), but I'm wondering if some widening like this is normal when the car is lifted from the jack point areas (i.e., using a two post lift) and, if so, how much one should expect. |
Claus Graf |
Dec 11 2014, 08:40 AM
Member Group: Members Posts: 51 Joined: 25-November 14 From: Houston, TX Member No.: 18,154 Region Association: None |
Had I done the test of opening the doors and jumping, my 74 914 would have split in half. So I removed the engine and trans. Built a wood frame with casters and put the 914 on top. This way the car would remain aligned while I cut and rebuild the longitudinals.
Attached thumbnail(s) |
worn |
Dec 21 2014, 07:52 PM
can't remember Group: Members Posts: 3,153 Joined: 3-June 11 From: Madison, WI Member No.: 13,152 Region Association: Upper MidWest |
Had I done the test of opening the doors and jumping, my 74 914 would have split in half. So I removed the engine and trans. Built a wood frame with casters and put the 914 on top. This way the car would remain aligned while I cut and rebuild the longitudinals. That wood frame looks great! I made a frame that held my TR6 out of half inch plywood. If you know about racking forces and diagonals they can be super strong. This is a car for which body work is not extra expensive in materials. A big length of sheet metal, restoration designs, amig or tig and off you go. But time will be an issue. Now parts, there you can spend the money. The porsche name seems to do something to the parts. |
Lo-Fi Version | Time is now: 12th May 2024 - 07:51 PM |
