Fuel pump question, Temporary switch to carbs |
JStroud |
Aug 11 2014, 07:59 AM
Senior Member Group: Members Posts: 1,463 Joined: 15-January 11 From: Galt, California Member No.: 12,594 Region Association: Northern California |
Ok I've pulled my 2.7 with CIS to do a rebuild, I've got a 2.7 with carbs I'm installing while my motor is down, trying to make it to RRC.
So my question, can I install the carb fuel pump and just leave my FI pump in place, will the carb pump be able to pull the gas thru the other pump( power disconnected ) or will I have to take it out. Or should I just use the FI pump and install a pressure regulator. The FI pump is in the front trunk(75-76 location) was thinking of just mounting the carb pump on the firewall in the engine compartment. This is just a temporary swap so trying to keep it simple, and easy to change back. Thanks, Jeff |
Lo-Fi Version | Time is now: 18th May 2024 - 03:42 AM |
