Quick 4x6 Speaker install, For those keeping the factory look |
914Sixer |
Aug 15 2014, 07:54 PM
914 Guru Group: Members Posts: 8,886 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
I am updating the sound in the orange 75. The factory speakers had crumbled. I pulled them out and went in search of some replacements. We all know that the speakers on the 914 were an odd duck mounting size. You have to also keep in mind that the speaker has to be low profile to clear the side wall. I found a set of Pyle coaxial speakers (4x6) that fit the objective. Of course, the speakers and mounts were not going to be plug and play but I found a way to make for a nice factory look fit.
I took the speakers apart and checked the mounting out. Mounts with grill would fit in the stock location mount with a little modification. I ground off about a 1/4" of plastic on each end of the mount to fit inside the speaker housing. Marked the mounts for notching and got out the files. Used a V file to start notch and then a round file for the mounting slot. Put the speakers back together and mounted them in the factory holes. I need longer screws. so I used the front turn signal lens screws, they were just the right length. I broke the speaker mounting clips in half and used it to secure the speaker mount to the factory grill. Attached image(s) |
Mikey914 |
Nov 9 2014, 12:59 PM
The rubber man Group: Members Posts: 12,670 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
My recollection is the clearance in the back is a good part of the issue. It would be nice to have a speaker that would fit.
Bump |
BeatNavy |
Nov 9 2014, 06:04 PM
Certified Professional Scapegoat Group: Members Posts: 2,924 Joined: 26-February 14 From: Easton, MD Member No.: 17,042 Region Association: MidAtlantic Region |
My recollection is the clearance in the back is a good part of the issue. It would be nice to have a speaker that would fit. Bump Are you planning something, Mikey? (IMG:style_emoticons/default/idea.gif) |
Lo-Fi Version | Time is now: 20th May 2024 - 08:54 AM |
