Broken valve spring., Valve spring is broken. |
mbseto |
Aug 16 2014, 04:02 PM
Senior Member Group: Members Posts: 1,253 Joined: 6-August 14 From: Cincy Member No.: 17,743 Region Association: North East States |
Hey all;
New 914 owner here. Just got a '71 1.7 with no compression in cyl #3. Popped the valve cover and there is a broken spring. Anyone tried to replace this with the engine in? Got a manual that only addresses the situation where the engine in on the bench. Thanks all, hope the BBQ is going well. Matthew. |
stugray |
Aug 16 2014, 06:40 PM
Advanced Member Group: Members Posts: 3,824 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None |
You need the type of compression tool that would bolt down where the rocker arms bolt.
Then you pressurize thru the plug hole to hold the valve out and press the sprig down over it. To talk about trying this with the engine in the car is kind of crazy. If the engine is out, you can have the head off in about an hour. |
Lo-Fi Version | Time is now: 14th May 2024 - 04:34 AM |
