Broken valve spring., Valve spring is broken. |
mbseto |
Aug 16 2014, 04:02 PM
Senior Member Group: Members Posts: 1,253 Joined: 6-August 14 From: Cincy Member No.: 17,743 Region Association: North East States |
Hey all;
New 914 owner here. Just got a '71 1.7 with no compression in cyl #3. Popped the valve cover and there is a broken spring. Anyone tried to replace this with the engine in? Got a manual that only addresses the situation where the engine in on the bench. Thanks all, hope the BBQ is going well. Matthew. |
mbseto |
Aug 18 2014, 08:12 AM
"1.7? sad.gif "
Eventual goal is a Suby... Not sure why it broke, I bought it this way. We were able to start it and drive it on to the trailer. No sounds of colliding metal, so the plan has been to repair what I find and then see what happens. Brian, I like your idea... It might be a moot point though. Upon further inspection, the pushrod end is chewed up, and the frame prevents me from pulling it out. I'd cut it, but still wouldn't be able to get the new one in. I was hoping to get the engine running without having to pull it, but this looks inevitable now... Thanks for all the responses. |
ChrisFoley |
Aug 18 2014, 11:08 AM
I am Tangerine Racing Group: Members Posts: 7,925 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
It might be a moot point though. Upon further inspection, the pushrod end is chewed up, and the frame prevents me from pulling it out. I'd cut it, but still wouldn't be able to get the new one in. Pull the pushrod tube at the same time. That way you can aim the pushrod at the angle necessary to get past the chassis. |
Lo-Fi Version | Time is now: 14th May 2024 - 11:11 AM |
