Improving dash light brightness? |
Cuda911 |
Aug 29 2014, 06:27 PM
Senior Member Group: Members Posts: 1,489 Joined: 20-May 14 From: Oceanside (N. San Diego County), CA Member No.: 17,376 Region Association: Southern California |
Thanks, Timothy.
Errghhh... OK, so I pulled out the bulb holder, but it's a completely different type of bulb. I ordered the ones that were linked by someone above. So, now what? Original bulb is a small type that has no base (at left in pic below): . Attached image(s) |
Cuda911 |
Aug 29 2014, 06:48 PM
I looked again... I guess the little bulb I pulled out is a turn signal bulb (see arrow below).
So, should I be pulling out the larger rounded post things (I assume the illumination bulb holders) circled below? I gave one of 'em a tug, and it didn't budge, but I don't want to break anything. . Attached image(s) |
Rob-O |
Aug 29 2014, 09:07 PM
Senior Member Group: Members Posts: 1,251 Joined: 5-December 03 From: Mansfield, TX Member No.: 1,419 Region Association: Southwest Region |
Yup, just pull those. You may want to twist them slightly back and forth to kind of break the seal, if you will. If you look at the wires running behind the gauges, you can identify them as the illumination circuit because they all have the same wiring color if I remember correctly.
I did the cool white bulbs and was less than impressed myself. I'll be hitting up Tim here shortly to convert mine. |
timothy_nd28 |
Aug 29 2014, 09:56 PM
Yep, only pull the lamp holders that are attached to a black/blue striped wire. Some pop out easy, while others are a PITA
Cuda911 |
Aug 29 2014, 11:00 PM
OK, thanks! I figured it was safest to ask here first, rather than breaking something and asking later.
Even if the LED's are just a bit brighter than the current bulbs, that will be good. |
Cuda911 |
Sep 14 2014, 10:00 PM
OK, finally got around to doing the bulbs today.
A few tips for other newbies: 1. Take out the screws that hold the cluster face plate and pull out the plate. But, you won't be able to pull it out far enough because of the speedometer cable. So, lift the cable off of the clip in the footwell. This will give enough "play" in the cable to let you pull out the face plate far enough to access the back of the gauges. 2. Push each gauge out of the faceplate from behind. 3. OK, a total newbie error, but might as well pass it on... to get the old bulb out, push in and turn. Sheesh, busted the first bulb trying to pull it straight out. Duh! 4. The metal bulb housings ground to the gauge cases, so once you replace a bulb you need to hold the bulb housing against the gauge case to test it. 5. Do not drop a bulb into the housing by accident, or you will have to disconnect everything to get it back out. (Ask how I know) 6. Those spade connectors are brittle. One of them broke, so I had to splice in a new female side Went for a drive tonight to see what difference it made. For the speedometer, makes a very significant improvement. Definitely worth it. For the tachometer, the left side is much brighter. Right side is still pretty dark. I'm wondering if one of the LEDs isn't working, so will take it apart again and check. Left gauge... parking brake warning light is much brighter. Fuel guage is still nearly unreadable at night (I think that has one of the tiny bulbs that is not the type that can be replaced with LED... I forgot.. Here's some pics and two videos. The first shows the OEM turn signal bulb, and the second shows it replaced with an LED. https://www.youtube.com/watch?v=fSvEb_r7BXo https://www.youtube.com/watch?v=5IphOdeOVTc Attached image(s) |
bluhun |
Sep 14 2014, 10:35 PM
Member Group: Members Posts: 91 Joined: 23-January 06 From: San Rafael, CA Member No.: 5,464 Region Association: Northern California |
OK, finally got around to doing the bulbs today. A few tips for other newbies: 1. Take out the screws that hold the cluster face plate and pull out the plate. But, you won't be able to pull it out far enough because of the speedometer cable. So, lift the cable off of the clip in the footwell. This will give enough "play" in the cable to let you pull out the face plate far enough to access the back of the gauges. 2. Push each gauge out of the faceplate from behind. 3. OK, a total newbie error, but might as well pass it on... to get the old bulb out, push in and turn. Sheesh, busted the first bulb trying to pull it straight out. Duh! 4. The metal bulb housings ground to the gauge cases, so once you replace a bulb you need to hold the bulb housing against the gauge case to test it. 5. Do not drop a bulb into the housing by accident, or you will have to disconnect everything to get it back out. 6. Those spade connectors are brittle. One of them broke, so I had to splice in a new female side Went for a drive tonight to see what difference it made. For the speedometer, makes a very significant improvement. Definitely worth it. For the tachometer, the left side is much brighter. Right side is still pretty dark. I'm wondering if one of the LEDs isn't working, so will take it apart again and check. Left gauge... parking brake warning light is much brighter. Fuel guage is still nearly unreadable at night (I think that has one of the tiny bulbs that is not the type that can be replaced with LED... I forgot.. Here's some pics and two videos. The first shows the OEM turn signal bulb, and the second shows it replaced with an LED. https://www.youtube.com/watch?v=fSvEb_r7BXo https://www.youtube.com/watch?v=5IphOdeOVTc The instrument control functions such as turn signal, etc. are illuminated by 1.2 watt bulbs manufactured by Osram. The bulb holders for gauge illumination can be purchased from AirCooled.net http://vwparts.aircooled.net/SearchResults.asp?Search=VDO For the tachometer I would replace the bulb and/or holder. I had the same problem when I replaced my incandescent bulbs with LEDs. |
VW Aircooled Society |
Jan 23 2019, 12:05 AM
Newbie Group: Members Posts: 10 Joined: 22-January 19 From: Miami, FL Member No.: 22,818 Region Association: None |
I just copycatted ALs work, just because his method was the only one that seemed to brighten these gauges up the most. Do a search with the LED bulb replacements, many people have mixed feelings with the results. I have a few threads explaining how to install these LED strips inside the gauges, it's really not that bad of a project just time consuming. If you take on this project, be sure to paint the inside of the gauge cans flat white, this is the best color to reflect the light. Also, with the tachometer, paint the back end of the bezel that holds the glass flat white. The gauge seems to be the dimmest due to the solid face dial. Timothy It's been 5 years since you posted on here in this thread so i am hoping that just maybe i might be able to get the response i need. I am using the following 914 Gauge Cluster on my 1964 Titled Meyers Manx Dune Buggy... I am curious as to the varios plastic covered glass lenses for the various lights on the instrument cluster such as Generator , Turn signals and such. Instead of going with the LED strips i have opted to replace the bulbs with BA7s LED bulbs I also see two sets of Blue receptacles and wonder which one is the high beam on the tachometer or the one on the speedometer ???? Should i use colored LED bulbs in the already corresponding plastic colored lens receptacle or just use the cool white LEDs (IMG:http://www.914world.com/bbs2/uploads/post-15438-1525435218.jpeg) (IMG:http://www.914world.com/bbs2/uploads/post-15438-1525435197.jpeg) |
dknechtly |
Sep 30 2020, 06:32 PM
Yellow 914 Group: Members Posts: 68 Joined: 11-April 03 From: Wylie, TX Member No.: 560 Region Association: None |
It's been 5 years since you posted on here in this thread so i am hoping that just maybe i might be able to get the response i need. I am using the following 914 Gauge Cluster on my 1964 Titled Meyers Manx Dune Buggy... I am curious as to the varios plastic covered glass lenses for the various lights on the instrument cluster such as Generator , Turn signals and such. Instead of going with the LED strips i have opted to replace the bulbs with BA7s LED bulbs I also see two sets of Blue receptacles and wonder which one is the high beam on the tachometer or the one on the speedometer ???? Should i use colored LED bulbs in the already corresponding plastic colored lens receptacle or just use the cool white LEDs (IMG:http://www.914world.com/bbs2/uploads/post-15438-1525435218.jpeg) (IMG:http://www.914world.com/bbs2/uploads/post-15438-1525435197.jpeg) [/quote] You will need to use the same color LED as the plastic. White LED's don't have the full color spectrum. The color will look washed out. |
FlacaProductions |
Sep 30 2020, 06:48 PM
Senior Member Group: Members Posts: 1,550 Joined: 24-November 17 From: LA Member No.: 21,628 Region Association: Southern California |
Use colored lights where they are going thru colored lenses. Red LEDs for Red lenses, etc.
HOWEVER - make sure to keep an incandescent bulb in the GEN position or it won't operate correctly. All others can be replaced with LED. |
barefoot |
Oct 5 2020, 09:31 AM
Senior Member Group: Members Posts: 1,268 Joined: 19-March 13 From: Charleston SC Member No.: 15,673 Region Association: South East States |
4 different bulb holders, 2 bulb styles & new LED options:
Left to right: spade remote ground, spade case ground, bayonet remote ground, bayonet case ground New LED lamp for spade holder, 3 OEM bulbs My Hi beam indicator lamp was barely visible even at night, now with new LED lamp, visible in daylight. Same lamp used in combo gage for backlighting, now brighter (IMG:style_emoticons/default/smile.gif) Purchased from Amazon Prior post shows LED lamps for the larger bayonet mount, which i hadn't seen before my quest for brighter lighting. Also got new LED lamps for Rear tail light outer most positions, same size fits rear trunk housing. |
VaccaRabite |
Oct 5 2020, 09:39 AM
En Garde! Group: Admin Posts: 13,420 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
I did the LED lights in the guage cluster ages ago and they really help.
One thing they do not do is DIM. When you turn the headlight switch the gauge lights are supposed to dim. The LED bulbs just turn off. After you forget this, and then bump the headlight switch with your knee one day, it will cause you to spend a few hours chasing wiring before you figure out why all your dash lights just died. Or... that's what i've been told... Zach |
barefoot |
Oct 6 2020, 04:49 PM
I did the LED lights in the guage cluster ages ago and they really help. One thing they do not do is DIM. When you turn the headlight switch the gauge lights are supposed to dim. The LED bulbs just turn off. After you forget this, and then bump the headlight switch with your knee one day, it will cause you to spend a few hours chasing wiring before you figure out why all your dash lights just died. Or... that's what i've been told... Zach My new LED lamps for instrument backlighting DO dim with with the headlight switch rotation. Before installation, I tested them with either terminal positive and they worked either way. |
bbrock |
Oct 6 2020, 05:15 PM
I did the LED lights in the guage cluster ages ago and they really help. One thing they do not do is DIM. When you turn the headlight switch the gauge lights are supposed to dim. The LED bulbs just turn off. After you forget this, and then bump the headlight switch with your knee one day, it will cause you to spend a few hours chasing wiring before you figure out why all your dash lights just died. Or... that's what i've been told... Zach I came across this thread a couple years ago while snooping around and filed it away in my brain to try sometime. Looks pretty slick. http://www.914world.com/bbs2/index.php?sho...=103294&hl= |
drem914 |
Feb 27 2021, 03:10 PM
Senior Member Group: Members Posts: 1,026 Joined: 16-May 08 From: Trabuco Canyon, CA Member No.: 9,062 Region Association: Southern California |
4 different bulb holders, 2 bulb styles & new LED options: Left to right: spade remote ground, spade case ground, bayonet remote ground, bayonet case ground New LED lamp for spade holder, 3 OEM bulbs My Hi beam indicator lamp was barely visible even at night, now with new LED lamp, visible in daylight. Same lamp used in combo gage for backlighting, now brighter (IMG:style_emoticons/default/smile.gif) Purchased from Amazon Prior post shows LED lamps for the larger bayonet mount, which i hadn't seen before my quest for brighter lighting. Do you have a listing for the colored spade bulbs you bought off Amazon? Were the ba7 lts. 2 watt LEDs? I have already swapped my bulbs previously for the single chip LEDs before they made the more powerful ones so I wanted to change the colored lts at the same time. Thanks for any info you can provide. |
barefoot |
Feb 28 2021, 05:57 PM
4 different bulb holders, 2 bulb styles & new LED options: Left to right: spade remote ground, spade case ground, bayonet remote ground, bayonet case ground New LED lamp for spade holder, 3 OEM bulbs My Hi beam indicator lamp was barely visible even at night, now with new LED lamp, visible in daylight. Same lamp used in combo gage for backlighting, now brighter (IMG:style_emoticons/default/smile.gif) Purchased from Amazon Prior post shows LED lamps for the larger bayonet mount, which i hadn't seen before my quest for brighter lighting. Do you have a listing for the colored spade bulbs you bought off Amazon? Were the ba7 lts. 2 watt LEDs? I have already swapped my bulbs previously for the single chip LEDs before they made the more powerful ones so I wanted to change the colored lts at the same time. Thanks for any info you can provide. here you go : DODOFUN High Bright White T5 37 74 PC74 PC37 LED Bulb with Twist Lock Socket for Dashboard Instrument Panel Gauge Cluster Light and Map Vanity Mirror Glove Box Indicator Light |
bandjoey |
Feb 28 2021, 06:12 PM
bandjoey Group: Members Posts: 4,923 Joined: 26-September 07 From: Bedford Tx Member No.: 8,156 Region Association: Southwest Region |
Just Do it the right way
http://www.914world.com/bbs2/index.php?showtopic=217100 triple the light you can do with bulbs. |
Spoke |
Feb 28 2021, 06:31 PM
Jerry Group: Members Posts: 6,972 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
My new LED lamps for instrument backlighting DO dim with with the headlight switch rotation. Before installation, I tested them with either terminal positive and they worked either way. @barefoot Can you expand on how these LEDs can be dimmed with the OEM headlight rheostat? |
drem914 |
Mar 1 2021, 09:45 AM
drem914 |
Mar 1 2021, 11:31 AM
Just Do it the right way http://www.914world.com/bbs2/index.php?showtopic=217100 triple the light you can do with bulbs. I will do that after I try with these more powerful LEDs for $20 (200 LM each vs 50 LM in the original LED bulb swap from Carmagic and 914Rubber.) https://www.amazon.com/gp/product/B08FR4FSW...ORAEU&psc=1 |
Lo-Fi Version | Time is now: 19th April 2024 - 08:26 PM |
