4 years of prep, 4 months of constant hard work...ready to start my 914-6 conversion., UPDATE: IT STARTED!!! |
patssle |
Aug 23 2014, 09:59 AM
Senior Member Group: Members Posts: 981 Joined: 28-August 09 From: Houston, TX Member No.: 10,741 Region Association: None |
My MSD ignition is dead. It worked great 2 years ago when I swapped the 3.0L engine to carbs and replaced the Bosch ignition. Less than 1 hour of runtime - now 2 years later of sitting in storage it's dead. I did accidently spark the main battery power cable once or twice - perhaps that did it in. I was ready to start the engine in the 914 for the first time this week! I even expedited a new coil to get it before the weekend.
So now I have to send it off and wait 2-3 weeks for it to be fixed. Grrr. What's really annoying is that I wanted to test the engine before I connect everything else - just in case I need to drop the engine and fix/change something. Grrrr. |
JRust |
Aug 24 2014, 11:10 AM
914 Guru Group: Members Posts: 6,307 Joined: 10-January 03 From: Corvallis Oregon Member No.: 129 Region Association: Pacific Northwest |
It's a never ending battle. Always frustrating to get put off a couple weeks. I'd just get everything bolted together & install. A this point you should be pretty good at dropping it if you need to later (IMG:style_emoticons/default/confused24.gif) . Right (IMG:style_emoticons/default/biggrin.gif)
Lo-Fi Version | Time is now: 26th May 2024 - 11:59 PM |
