Am I Over Carbed?, Dual Weber 40 IDFs on 1.7 |
7TPorsh |
Aug 25 2014, 10:52 AM
7T Porsh Group: Members Posts: 2,691 Joined: 27-March 06 From: Glendale Ca Member No.: 5,782 Region Association: Southern California |
I have been trying to drive my car comfortably but I am running across issues. Mainly after the car warms up it starts acting weird.
Coming to a stop and revs dropping. it just dies. Then I have to wait a minute or two to get started again. Then it runs a little rough, pops, backfires. Just did the valves, points, timing but runs like crap when hot. The engine is a 1.7 block with 1.7 heads and dual 40s. I don;t know if there was any work done internally but the block is a 71 and car is a 70. It has been suggested that I am way overcarbed and running rich. i have no plans of building out this motor to match the carburation. Am I better off selling off this dual weber set and putting on a single Weber 32/36? I have my eye on this: http://www.ebay.com/itm/310953732343?ssPag...984.m1423.l2649 I am thinking the weber and hex setup should be worth around $450? What say you? |
stugray |
Aug 25 2014, 11:03 AM
Advanced Member Group: Members Posts: 3,824 Joined: 17-September 09 From: Longmont, CO Member No.: 10,819 Region Association: None |
The carb bodies should be fine.
What size venturis do you have? You should be running the smallest you can find. Someone on here makes them with their 3D printer. If you could get a set to try out, you would know if that was your problem before spedning the cash on a complete set of permanent ones. |
Lo-Fi Version | Time is now: 17th May 2024 - 04:05 PM |
