> Am I Over Carbed?, Dual Weber 40 IDFs on 1.7
7TPorsh
post Aug 25 2014, 10:52 AM
7T Porsh
I have been trying to drive my car comfortably but I am running across issues. Mainly after the car warms up it starts acting weird.
Coming to a stop and revs dropping. it just dies. Then I have to wait a minute or two to get started again. Then it runs a little rough, pops, backfires.
Just did the valves, points, timing but runs like crap when hot.
The engine is a 1.7 block with 1.7 heads and dual 40s. I don;t know if there was any work done internally but the block is a 71 and car is a 70.
It has been suggested that I am way overcarbed and running rich. i have no plans of building out this motor to match the carburation.
Am I better off selling off this dual weber set and putting on a single Weber 32/36?
I have my eye on this: http://www.ebay.com/itm/310953732343?ssPag...984.m1423.l2649
I am thinking the weber and hex setup should be worth around $450?
What say you?
rhodyguy
post Aug 25 2014, 01:12 PM
where does the pass side line from the bb terminate? just stuck thru the tin and spewing under the car?
7TPorsh   Am I Over Carbed?   Aug 25 2014, 10:52 AM
rhodyguy   look down one of the venturis and see if a number ...   Aug 25 2014, 11:01 AM
Alapone   I have been trying to drive my car comfortably bu...   Aug 25 2014, 11:03 AM
stugray   The carb bodies should be fine. What size venturi...   Aug 25 2014, 11:03 AM
7TPorsh   I am a total novice when it comes to fuel delivery...   Aug 25 2014, 12:14 PM
stugray   you have to remove the air filters. Then look down...   Aug 25 2014, 12:21 PM
rhodyguy   for your reference. the venturis look like this. t...   Aug 25 2014, 12:26 PM
rhodyguy   where does the pass side line from the bb terminat...   Aug 25 2014, 01:12 PM
7TPorsh   where does the pass side line from the bb termina...   Aug 25 2014, 02:23 PM
Kansas 914   where does the pass side line from the bb termin...   Aug 25 2014, 02:44 PM
7TPorsh   wow, I haven't noticed anything like that on m...   Aug 25 2014, 02:53 PM
Rand   Hopefully you've heard feedback that says NEV...   Aug 25 2014, 02:58 PM
ThePaintedMan   Not all 1.7s had head vents - it's only the ea...   Aug 25 2014, 02:58 PM
Kansas 914   Not all 1.7s had head vents - it's only the e...   Aug 25 2014, 03:05 PM
Kansas 914   Not all 1.7s had head vents - it's only the ...   Aug 25 2014, 03:08 PM
rhodyguy   if you have those head tubes…one line from the p...   Aug 25 2014, 02:58 PM
wndsnd   I do not think you are over carbed at all. You ju...   Aug 25 2014, 06:16 PM
Mblizzard   I think you may need to check your float level set...   Aug 25 2014, 06:27 PM
7TPorsh   Ok I checked one of the throats...assuming all fou...   Aug 27 2014, 09:44 AM
AE354803   Am I the only one that is impressed by how clear t...   Aug 28 2014, 12:30 PM
stugray   Next check all of the jets and write down the numb...   Aug 27 2014, 10:22 AM
rhodyguy   if you haven't done so, order or go to a vw pa...   Aug 27 2014, 11:24 AM
maf914   Along with the Tomlison Webber Manual above, you m...   Aug 28 2014, 06:22 AM
Mike Bellis   I have been trying to drive my car comfortably bu...   Aug 28 2014, 07:33 AM
7TPorsh   I haven't had a chance to look at the jets yet...   Aug 28 2014, 09:24 AM
rhodyguy   the tomlinson book is $20. stating 'idle ...   Aug 28 2014, 10:32 AM
ThePaintedMan   Gary, Kevin and Stu have given you great tools t...   Aug 28 2014, 10:38 AM
rhodyguy   george has travel the path you're on. to the p...   Aug 28 2014, 10:52 AM
- Lo-Fi Version Time is now: 17th May 2024 - 02:28 PM
