Engine Removal with pics, A newbie-rated write-up |
doug_b_928 |
Aug 25 2014, 01:10 PM
I recently removed the engine on my 73 for the first time. I used Wayne Dempsey's write-up from Pelican and it was very helpful. But I would have benefited from more detail to take some of the remaining mystery out of the procedure. Attached is a pdf of what I did in my engine removal. I thought I'd post it for any other newbies that are contemplating doing this for the first time. If there are any mistakes, please let me know. Special thanks to Brad Smith from Rennlist for compressing the file so that it would be small enough to attach to this thread.
1973_914_Engine_Removal_Compressed.pdf ( 2.86mb ) Number of downloads: 1696 |
doug_b_928 |
Aug 26 2014, 11:21 AM
Thanks guys. Good tip about the axles. I put the car on a bench so it wasn't necessary in my case.
Jeff, what does mps stand for? |
BeatNavy |
Aug 26 2014, 12:53 PM
Thanks guys. Good tip about the axles. I put the car on a bench so it wasn't necessary in my case. Jeff, what does mps stand for? Manifold pressure sensor. Often described as the thing that looks like a "grenade." From Anders' site: •Function: The manifold pressure sensor senses engine load by converting the intake manifold pressure level to an electrical signal that the ECU uses to set the basic injection pulse duration. A special part of the sensor operates at full-load, signaling the ECU to richen the mixture further. As others have said, great work! (Although I had to do this a few weeks ago and could have benefited from it then. Do me a favor and do the install procedure (IMG:style_emoticons/default/smile.gif) .) |
Lo-Fi Version | Time is now: 2nd May 2024 - 06:53 PM |
