Off Topic Question, Cut out on VW Jetta |
partwerks |
Aug 25 2014, 10:01 PM
Senior Member Group: Members Posts: 1,593 Joined: 7-September 06 From: Grand Island, NE Member No.: 6,787 |
Within the first 4 minutes of a cold engine, my 96 VW Jetta, has this thing where it will intermittently cut out. If you happen to be stopped, one of two things, if you let it run it's course, then the idle will fluctuate up and down from about 700 to 900 for about 5 seconds, or there abouts, and then the idle goes high to about 1200, for about 5 seconds, and comes down to normal idle.
On the other hand, if you slam the pedal down, and let back up quck, it tends to clear it out, and everything is normal. Otherwise, it runs just fine once it has it's fit. I've cleaned all the grounds that I know of, and replaced the coolant temp sensor, and throttle body, but not sure what is causing it?? I'm hoping someone might have an idea on what is causing it. It would almost make me think that it is something that when it first warms up? Any, thoughts, ideas, or suggestions? |
76-914 |
Aug 26 2014, 09:17 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,494 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
What codes is the ECM throwing?
AfricanHijinx |
Aug 26 2014, 10:01 AM
Member Group: Members Posts: 132 Joined: 12-April 11 From: Snohomish WA Member No.: 12,928 Region Association: Pacific Northwest |
Within the first 4 minutes of a cold engine, my 96 VW Jetta, has this thing where it will intermittently cut out. If you happen to be stopped, one of two things, if you let it run it's course, then the idle will fluctuate up and down from about 700 to 900 for about 5 seconds, or there abouts, and then the idle goes high to about 1200, for about 5 seconds, and comes down to normal idle. On the other hand, if you slam the pedal down, and let back up quck, it tends to clear it out, and everything is normal. Otherwise, it runs just fine once it has it's fit. I've cleaned all the grounds that I know of, and replaced the coolant temp sensor, and throttle body, but not sure what is causing it?? I'm hoping someone might have an idea on what is causing it. It would almost make me think that it is something that when it first warms up? Any, thoughts, ideas, or suggestions? check your PCV and your vacuum lines |
SirAndy |
Aug 26 2014, 11:13 AM
Resident German Group: Admin Posts: 41,611 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Is it a complete cutout or just loss of power but still moving?
I had a problem on my 2002 VR6 where my spark plug wires were going bad and the symptoms were sporadic loss of power (but not complete cutout). (IMG:style_emoticons/default/idea.gif) |
partwerks |
Aug 26 2014, 08:44 PM
There is no engine check light that is coming on.
I just put on new wires about 7 months ago, and distributor cap, maf, throttle body. I've been also told to check something called the ISV and the back of the intake manifold where that hose connects to? Not sure what that is? I'm not sure where it is located at: http://www.ebay.com/itm/New-Idle-Control-V...=p2054897.l4275 Not a complete cut out. Just like pulling a plug wire randomly off and on. |
partwerks |
Aug 27 2014, 09:35 PM
Well I hope the mechanic finds out what it's problem is. It did not want to stay running this morning, but for about 5 seconds, and shut off. No engine check light. I was able to limp it down to a mechanc about a mile across town, with restarting it about 25 times. When konking out, I would let it roll a ways, and kept millking it. Sometimes to floor board it, it would tend to catch, but definitely is NOT running right.
I don't know if there are codes that don't set off the engine check light, that may show up on a scanner? |
partwerks |
Aug 29 2014, 09:41 PM
Took it to the mechanic:
Ck codes17535, fuel trim bank 1, system too rich P1127, 16486 Mass air flow sensor signal too low PO102, found intake air hose off of throttle body, cleaned MAF sensor. Only thing that didn't make sense, is if it is the hose that hooks to that brass fitting on the TB, as I recall, it was on there the first time I opened the hood to try and see what the whole ordeal was about. It doesn't pull off easy, and was a hose clamp holding it on. Unless he was talking about some other hose, and/or was a bit loose or something, but probably would have noticed that when I opened the hood the first time, if it was off, but runs good now........... I don't see any other hose on the TB? |
steuspeed |
Aug 29 2014, 09:51 PM
Senior Member Group: Members Posts: 1,005 Joined: 12-July 11 From: Portland, Oregon Member No.: 13,308 Region Association: Pacific Northwest |
Try posting on http://forums.vwvortex.com/
Lo-Fi Version | Time is now: 2nd May 2024 - 09:30 PM |
